How Do Disjoint Intervals Solve the Inequality in POTW #409?
  • MHB
  • Thread starter anemone
In summary, disjoint intervals for inequality are numerical intervals that do not overlap with each other and are used to represent inequalities in mathematical equations. They are commonly used in statistical analysis and modeling in scientific research to represent relationships between variables, and can also be applied to real-world situations. Disjoint intervals for inequality are different from other types of intervals because they do not share any common values, making them a clear representation of inequalities. However, they may not always accurately represent relationships between variables, and other methods may be more suitable for analyzing inequalities in scientific research.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Show that the set of real numbers $x$ which satisfy the inequality \(\displaystyle \sum_{k=1}^{70}\dfrac{k}{x-k}\ge \dfrac{5}{4}\) is a union of disjoint intervals, the sum of whose lengths is 1988.
Remember to read the https://mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to https://mathhelpboards.com/forms.php?do=form&fid=2!
Hi MHB!
I have decided to extend the deadline by another week so that our members can give this problem another shot and I am looking forward to receive submissions of the solution from the members!(Happy)
No one answered to POTW #409.
Here is a suggested solution from other:
The function \(\displaystyle S(x)=\sum_{k=1}^{70}\dfrac{k}{x-k}\) is discontinuous at $x=k$ for $k=1, 2, ..., 70$ but is continuous in the open intervals between these integers. Also, the function goes to $-\infty$ as $x$ approaches $k$ from below and to $+\infty$ as $x$ approaches $k$ from above. Thus the graph crosses the line $y=\dfrac{5}{4}$ in each of the interval $(k, k+1)$ for $k=1, 2, ..., 69$.
For $x>70$, the biggest term in $S(x)$, namely $\dfrac{70}{x-70}$, gets arbitrarily small as $x$ increases, showing that the positive $x$-axis is an asymptote. Therefore from a sketch of the graph of $y=S(x)$, we can see that the set of values of $x$ for which $S(x)\ge \dfrac{5}{4}$ consists of 70 half-open intervals, open on the left and closed on the right, which begin respectively at the integer points $x=1, 2, ..., 70$.
In fact, in the graph of $y=S(x)-\dfrac{5}{4}$, these intervals occurs on the $x$-axis as the intervals between $k$ and the root $x_k$ of the equation $S(x)-\dfrac{5}{4}=0$ which lies between $k$ and $k+1$. The length of the $k$th interval, then, is simply $x_k-k$, and the sum of all 70 intervals is
$(x_1-1)+(x_2-2)+\cdots+(x_{70}-70)=(x_1+x_2+\cdots+x_{70})-(1+2+\cdots+70)$
It remains, then, only to show that the sum of the roots of $S(x)-\dfrac{5}{4}=0$ is $1988+(1+2+\cdots+70)$.
If $S(x)-\dfrac{5}{4}=ax^{70}+bx^{69}+\cdots$, the sum of the roots is simply $-\dfrac{b}{a}$.
$S(x)-\dfrac{5}{4}=\dfrac{1}{x-1}+\dfrac{2}{x-2}+\cdots+\dfrac{70}{x-70}-\dfrac{5}{4}=0$
Clearing the fraction we get
$4(x-2)(x-3)\cdots(x-70)+4\cdot2(x-1)(x-3)\cdots(x-70)+\cdots+4\cdot70(x-1)(x-2)\cdots(x-69)-5(x-1)(x-2)\cdots(x-70)=0$
$-5x^{70}+x^{69}[4\cdot1+4\cdot2+\cdots+4\cdot70-5(-1-2-\cdots-70)]+\cdots=0$
$-5x^{70}+x^{69}[4(1+2+\cdots+70)+5(1+2+\cdots+70)]+\cdots=0$
$-5x^{70}+9(1+2+\cdots+70)x^{69}+\cdots=0$$\begin{align*}-\dfrac{b}{a}&=-\dfrac{9(1+2+\cdots+70)}{-5}\\&=(1+2+\cdots+70)+\dfrac{4(1+2+\cdots+70)}{5}\\&=(1+2+\cdots+70)+\dfrac{4}{5}\dfrac{70}{2}(1+70)\\&=(1+2+\cdots+70)+1988\text{ (Q.E.D.)}\end{align*}$
FAQ: How Do Disjoint Intervals Solve the Inequality in POTW #409?
What are disjoint intervals for inequality?
Disjoint intervals for inequality refer to a set of non-overlapping intervals on a number line that represent a range of values that do not satisfy a given inequality.
How are disjoint intervals used in scientific research?
Disjoint intervals are commonly used in data analysis and statistical modeling to represent a range of values that fall outside of a certain threshold or criteria. They can also be used to identify patterns and trends in data.
Can disjoint intervals be used for both numerical and categorical data?
Yes, disjoint intervals can be used for both numerical and categorical data. In numerical data, the intervals represent a range of values, while in categorical data, the intervals represent distinct categories or groups.
How do you determine the number of disjoint intervals needed for a given dataset?
The number of disjoint intervals needed for a given dataset depends on the complexity and variability of the data. It is typically determined through statistical analysis and can vary depending on the research question and goals.
Are disjoint intervals the only way to represent inequalities in data?
No, there are other methods for representing inequalities in data, such as using graphs, charts, or equations. Disjoint intervals are just one way to visually represent inequalities and may be more suitable for certain types of data or research questions.
