How do electrons move? [Please read]
  • Thread starter Ziggs
  • Tags
    Electrons
In summary, the discussion is about Zeno's paradoxes and how they relate to the movement of an electron. It is argued that due to the Quantum Zeno Effect, the electron is able to "jump" and bypass the infinite amount of time it would take to move from one point to another.
Ziggs
Bear in mind, I may be very misinformed, I'm going from something I found on this forum a while back. Are you sitting comfortably? Well I'll begin.
If the electron is indeed a point particle (zero volume) then how can it move without teleportation (of sorts) because say an electron has traveled 1 meter (free electron, just a simple electron, not in a field or anything) then at one point it must be half way there, 50cm, and then it must be half way to there (25cm) and then it must be half way there at some point (12.5cm) you get the point, yea?
So if this is indeed true (It might not be, please correct me) Then even after an infinite number of halves, it's still not 1 'measure of movement' away from itself at the start because it can never be touching itself, therefore to get to the '2nd' location it needs to go an infinite number of 'movements' therefore it would take an eternity to move 1 'movement' (as in the smallest measurement of movement, when you move you don't teleport, you have to take up every possible location between start/end point) This keeps repeating so basically to move an infinitely small distance then it would take an infinite amount of time.
/Discuss
We only know what we can measure. If you measure the electron at point A and then again at point B, then that's all you know. You can't really infer that the electron was at some point between A and B unless you actually measure it there.
Actually, if you keep continuously making measurements of where the electron is, then it will an infinite amount of time to move from A to B, due to the Quantum Zeno Effect.
http://en.wikipedia.org/wiki/Quantum_Zeno_effect
But because we don't constantly measure the position, the electron is allowed to "jump", bypassing the Zeno effect.
Related to How do electrons move? [Please read]
1. How do electrons move in an atom?
Electrons move in an atom by orbiting around the nucleus in specific energy levels or shells. These shells are further divided into subshells, and each subshell can hold a specific number of electrons. The movement of electrons within an atom is also influenced by the attractive force of the positively charged nucleus and the repulsive force between electrons.
2. What causes electrons to move?
Electrons move due to the presence of an electric field or a potential difference. When a difference in electric potential exists between two points, electrons will move from the point of higher potential to the point of lower potential. This movement of electrons is known as an electric current.
3. Can electrons move in a vacuum?
Yes, electrons can move in a vacuum. In fact, they are able to move more easily in a vacuum compared to a medium such as air or water. This is because there are no other particles present in a vacuum to impede their movement, allowing them to flow freely.
4. How do electrons move in an electrical circuit?
In an electrical circuit, electrons move from the negative terminal of a battery or power source towards the positive terminal. This flow of electrons creates an electric current, which can power various devices and appliances. The movement of electrons in a circuit follows the path of least resistance, and the rate of movement is determined by the voltage and resistance in the circuit.
5. Can electrons move faster than the speed of light?
No, according to the theory of relativity, the speed of light is the maximum speed at which anything in the universe can travel. Electrons are no exception to this rule and cannot move faster than the speed of light. However, within the realm of an atom or a circuit, electrons can move at high speeds, but they cannot exceed the speed of light.
  • Classical Physics
  • Electromagnetism
  • Quantum Physics
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
