How do gravitational waves differ from the expansion of the Universe?
In summary: With this type of detector, the effects of gravitational waves are (in theory) compared to the elastic restoring force of the bar, which is some form of solid matter.So both the elastic "strength" of spacetime and the elastic strength of the Earth (or a bar) are at play in different types of detectors, but it is not correct to say that the Earth itself is "stretched and squeezed" by gravitational waves.In summary, gravitational waves do not directly affect the Earth or other solid objects. They are localized fluctuations in the background spacetime geometry caused by massive objects, such as merging black holes. The expansion of the universe, on the other hand, does not have a significant effect on the small scale, such
Andy DS
TL;DR Summary
How do gravitational waves in spacetime stretch and compress solid matter such as the LIGO experiment. I ask this because the expansion of spacetime of the Universe doesn't seem to have any effect on the small scale ie the solar system.
Astronomy news on Phys.org
I think I can explain if I understand your question correctly. Even though gravitation and the particle that goes with it is universal, there is a locality to it. An object will experience the ripples of a wave from a boat, but another object in a different body of water or far away will not experience that wave. So, the gravity acting at the edge of the universe will not affect our miniscule solar system inside the Milky Way galaxy.
This is correct and is true for gravitationally bound systems. The expansion of the universe has no effect on the tendency of gravitational waves to stretch and compress things because this is a local effect.
The global effect of the expansion of the universe is that gravitational waves like electromagnetic waves are observed redshifted far away from the source.
Thanks, but I'm not sure if I explained my query correctly, if gravitational waves from merging black holes stretch space time which has let's say infinite elasticity how does it manage to stretch the earth, which is much less elastic, to show up on the LIGO experiment. In other words do changes in the dimension of space time have an equal effect on the dimension of solid objects or does it depend on its elasticity.
LIGO doesn't measure the stretching of earth, see Vibration Isolation.
I am not sure if gravitational waves stretch and compress the Earth to a certain extent, if at all then presumably much less than the distances between the isolated mirrors.
The LIGO mirrors are incredibly sensitive to local changes in spacetime and hang by tiny glass threads. There's a video about this here:
https://www.ligo.caltech.edu/video/ligo20170216v
The gravitational waves are not "streching and compressing solid objects". They are changing the distance between extraordinarily sensitively balanced mirrors, that move at the smallest vibration.
The universal expansion depends on the overall density of matter across the universe generally. The solar system, compared to the universe as a whole, is dominated by matter and has settled into an equilibrium dominated by the gravity of the Sun and the other planets. And, solid objects on Earth are even less influenced by the factors that cause universal expansion.
The universe as a whole is much less dense and hence the dynamics are very different. Moreover, as the universe expands, its density decreases and this increases the infleunce of the vacuum energy (dark energy) and hence the expansion rate is increasing.
I can't see a meaningful comparison between expansion and gravitational waves.
Likes 256bits
Whelp, thread locked temporarily for cleanup...
Likes PhDeezNutz
Moderator's note: An off topic and misleading subthread has been deleted. Thread reopened.
That is true, but gravitational waves are not the same thing as the expansion of the universe. The expansion of the universe, in this context, is best viewed as providing a "background" spacetime geometry, on which gravitational waves are localized fluctuations.
There is a viewpoint in which spacetime can be viewed as a sort of elastic medium (among others, Sakharov, the famous Russian physicist, worked on this sort of model in the 1960s), but in this view, the elasticity is not infinite.
As has already been noted, LIGO does not measure the stretching and squeezing of the Earth by gravitational waves. It measures the stretching and squeezing of the arms of a very precisely constructed and sensitive detector which, as has been noted, is carefully isolated from all other external sources of vibration, including the Earth.
There is another type of gravitational wave detector called a bar detector, originally invented by Weber and worked on several decades ago by a Russian team led by Braginsky (this work is described in the popular book Black Holes and Time Warps by Kip Thorne), which does measure the stretching and squeezing of a solid object (a large bar, usually of a metal like iron) by gravitational waves. Braginsky's work showed that this type of detector has serious limitations which probably make it unable to detect gravitational waves coming to Earth from distant sources, given the expected strength of those waves (now confirmed by LIGO). That limitation was one of the main reasons why LIGO used interferometer-type detectors.
Likes berkeman and PeroK
Andy DS said:
Summary:: How do gravitational waves differ from the expansion of the Universe
I'm basically an Engineer and I can't help interpreting this question in terms of AC vs DC measurement in the presence of noise. With nothing to compare local distances with and without Expansion then it seems that we have no chance of detecting it. With gravitational waves, we have changes with time so we can 'filter' the data and squeeze something out of what very sensitive equipment will show.
Is this nonsense or is it bringing the question into more familiar territory?
What I was trying to get to the bottom of is that, do the mirrors in the LIGO experiment actually move in response to gravitational waves or is that the time it takes the light to travel between them somehow modulated.
You can interpret the LIGO measurements several ways - it's a matter of choice as long as you respect the invariant fact that the flight time of the light varies as the wave comes through. I think the most usual interpretation is to regard the distance between the mirrors as changing (whether you say the mirrors have moved or just that the distance changed is also a choice), but it's not obligatory. You can treat the speed of light as varying if you like, or if it makes some computation easier.
These are not two different possible ways things could be. They are just two different descriptions of the same way things are. There is no such thing as "actually move"--"move" is frame dependent. So by an appropriate choice of coordinates, one can have the mirrors "moving" (spatial coordinates changing with time) and the coordinate speed of light constant, or one can have the mirrors "stationary" (spatial coordinates not changing with time) and the coordinate speed of light inside the apparatus changing with time.
FAQ: How do gravitational waves differ from the expansion of the Universe?
What are gravitational waves?
Gravitational waves are ripples in the fabric of spacetime, caused by the acceleration of massive objects. They were first predicted by Einstein's theory of general relativity and were recently detected by the Laser Interferometer Gravitational-Wave Observatory (LIGO).
How do gravitational waves differ from electromagnetic waves?
Gravitational waves are fundamentally different from electromagnetic waves in that they do not require a medium to travel through. Electromagnetic waves, such as light, require a medium (such as air or a vacuum) to propagate, while gravitational waves can travel through empty space.
Gravitational waves and the expansion of the Universe are both consequences of general relativity, but they are different phenomena. Gravitational waves are caused by the motion of massive objects, while the expansion of the Universe is the overall stretching of space itself.
How are gravitational waves detected?
Gravitational waves are detected using specialized instruments, such as the LIGO detectors, which measure tiny changes in the length of laser beams caused by passing gravitational waves. These changes are incredibly small, on the order of a thousandth of the width of a proton.
What is the significance of detecting gravitational waves?
The detection of gravitational waves is a major scientific breakthrough that confirms a key prediction of Einstein's theory of general relativity. It also opens up a new window for studying the Universe, as gravitational waves can provide unique information about some of the most extreme and energetic events in the Universe, such as black hole mergers and supernova explosions.
