How Do Gymnasts Balance Forces During an Iron Cross?
  • Thread starter way2whack
  • Tags
    Cross Iron
In summary, a gymnast performing an Iron Cross with a mass of 65.00 kg is in static equilibrium with symmetric forces in the cables. A free body diagram of the gymnast shows the tension in the two ropes acting on his hands. The vertical and horizontal components of the cable force on his left hand are 318.83 N and -56.13 N respectively. The moment generated around his left shoulder by the cable forces is -68.60 Nm. This moment is resisted by the shoulder adductors, as shown by the negative direction of the moment and their responsibility for moving the arms in. If the cables were vertical instead of tilted inwards, it would be easier to hold this move as the moment would be
way2whack
Gymnast pictured below performing an Iron Cross has a mass of 65.00 kg. Assume that the forces
in the cables are symmetric and that he is in static equilibrium.
A. Draw a complete free body diagram of the gymnast (just him – he is the system).
B. Calculate the vertical and horizontal components of the cable force acting on his left hand.
**answer: vertical component = 318.83 N horizontal component = -56.13 N**
C. Calculate the moment generated around his left shoulder by the forces in the cable. Make sure you include both components of the cable force.
**answer: -68.60 Nm**
D. Is this moment resisted by the shoulder abductors or adductors? Explain your choice using the results from part C. **answer: This moment is resisted by the shoulder adductors because shoulder abductors are responsible for moving muscles on the arms out to the side, which is a positive moment based on my assignment of rotation. However, my answer was a negative moment about the shoulder joint means the muscles responsible were moving the arms in (clockwise on the left arm).**
E. Would it be harder or easier to hold this move if the cable was vertical instead of tilted inwards? Explain your answer. **I have no idea**
F. If the shoulder muscles have an average moment arm around the shoulder joint of 40 mm, what is the total force required by those muscles to maintain this position? **I have no idea**
http://i.imgur.com/VNdfQ.png <-- picture of gymnast
We should really consider his weight will be acting at this point. Hence the free body diagram will have the force of his weight, and the tension in the two ropes acting on his hands.
The components of the tension you seem to have done correctly.
Part C, moment = force x perpendicular distance from force to pivot
The total tension you work out from Pythagorus, using the two components you have calculated, The perpendicular distance is .62cos 20. You might need to draw out the diagram to convince yourself of this. You can then calculate the moment
D The tension is trying to pulls the arms up, he must pull them down in order to counter this.
E If the cable was vertical then the moment would be = 1/2mass x g perpendicular distance, so just calculate this moment and compare it to your previous answer.
Question F. 40mm is the distance from the pivot to where the force is acting in a shoulder joint, I assume it is referring to the position held in question E.
Hence moment calculated in E = Force x distance(m)
rearrange this for force.
Related to How Do Gymnasts Balance Forces During an Iron Cross?
1. What is an Iron Cross in gymnastics?
An Iron Cross is a difficult and iconic gymnastics move that involves holding the body parallel to the ground with arms straight out to the sides. It requires a combination of strength, flexibility, and balance.
2. How is an Iron Cross performed?
To perform an Iron Cross, a gymnast must hold onto two rings or bars and extend their arms out to the sides, keeping the body straight and parallel to the ground. The legs should also be extended and held together, with the toes pointed.
3. What muscles are used in an Iron Cross?
The primary muscles used in an Iron Cross are the chest, shoulders, and arms. However, the move also requires strong core muscles to maintain balance and stability.
4. How do gymnasts train for an Iron Cross?
Gymnasts train for an Iron Cross by focusing on building upper body strength, particularly in the chest, shoulders, and arms. They also work on improving flexibility and balance through specific exercises and drills.
5. What are some common mistakes when attempting an Iron Cross?
Some common mistakes when attempting an Iron Cross include not engaging the core muscles enough, not having enough strength in the arms and shoulders, and not keeping the body straight and parallel to the ground. It is also important to have proper form and technique to avoid injury.
9K
