natalie.*
- 8
I had this https://www.physicsforums.com/showthread.php?p=3200140#post3200140", which I posted on PF. I got the answer, but then I started thinking more about it and have some theoretical questions.
If you did have this particle of mass m in a box of length L, which you are trying to stop, you know that by the Heisenberg Uncertainty Principle,[tex]\Delta x \Delta p_{x}\geq\frac{h}{2}[/tex], you can only know it's velocity within the range [tex]\Delta v=\frac{h}{2Lm}[/tex]. That means (the answer to the homework question) the velocity of the particle must be in the range [tex]-\frac{1}{2}*\frac{h}{2Lm}\leq v \leq \frac{1}{2}*\frac{h}{2Lm}[/tex] (I think coming to this conclusion is where there's a problem but I'm not sure).
According to the whole de Broglie wave-like nature of the particle thing though, it only has discrete, quantized, allowable energies, and therefore velocities, according to [tex]v_{n}=n\frac{h}{2Lm}[/tex], which looks a lot like the equation from the Heisenberg Uncertainty Principle, but that equation, where n is a natural number, says that the lowest possible speed of the particle must be [tex]\frac{h}{2Lm}[/tex].
I get that for the sake of the question you're just ignoring the matter wave thing, but I just want to reconcile this in my head. The two formulas obviously look so similar, but I just can't make them work together. How should I be thinking about it?
