How do i account for the height for projectile motion
Ok, but you should distinguish horizontal velocities from vertical ones, not use the same symbol for both.That gives you six variables on the right hand sides of those equations. Which of these do you have values for?In summary, a child throws a ball with an initial speed of 8.00 m/s at an angle of 40.0° above the horizontal, and the ball leaves her hand 1.00 m above the ground. To find the distance from where the child is standing to where the ball hits the ground, we can use the equation R(θ) = v0^2(sin(2θ))/g. To find the time the ball is in flight before hitting the ground, we can use the equation
rashad764
A child throws a ball with an initial speed of 8.00 m/s at an angle of 40.0° above the horizontal. The ball leaves her hand 1.00 m above the ground and experience negligible air resistance.
(a) How far from where the child is standing does the ball hit the ground?
(b) How long is the ball in flight before it hits the ground?
R(θ) = v0^2(sin(2θ))/g for a
2v0(sinθ)/g for b
the above formulas assume that the object is at ground level, however the question says the object leaves 1m above the ground. how do i use the above formulas knowing this
2v0(sinθ)/g for b
Use the full set of kinematic equations for motion in a force field with constant acceleration (gravity). Are you familiar with them? Can you post them? :smile:
EDIT/ADD -- You don't need all of the equations (there are 3-4) for this problem, but it's good to be familiar with them anyway. You need different combinations of them for different problems...
i'm not, can you post the ones that i need to know
Write the equations for the vertical (y) and horizontal (x) positions as a function of time. The horizontal position only depends on the initial horizontal velocity (because there is no acceleration in the horizontal direction after the ball is released). The vertical position as a function of time depends on the initial vertical displacement, the initial vertical velocity, and the vertical acceleration (from gravity).
Please write out the equations that you think you should use, and work with them. The initial release point and velocities and the final impact point are related.
x=v0t+x0
y=1/2at^2+v0t+y0
rashad764 said:
x=v0t+x0
y=1/2at^2+v0t+y0
Likes berkeman
FAQ: How do i account for the height for projectile motion
What is projectile motion?
Projectile motion is the motion of an object through the air under the influence of gravity. It follows a curved path known as a parabola.
How do I account for the height in projectile motion?
To account for the height in projectile motion, you must consider the initial vertical velocity of the object, the acceleration due to gravity, and the time the object spends in the air. These factors can be used to calculate the maximum height reached by the projectile.
What is the equation for calculating the height in projectile motion?
The equation for calculating the height in projectile motion is h = (v02sin2θ)/2g, where h is the height, v0 is the initial velocity, θ is the angle of projection, and g is the acceleration due to gravity.
How does the angle of projection affect the height in projectile motion?
The angle of projection directly affects the height in projectile motion. The higher the angle, the higher the projectile will travel. A lower angle will result in a shorter distance and height.
What are some real-life examples of projectile motion?
Some real-life examples of projectile motion include throwing a ball, kicking a soccer ball, and shooting a basketball. Other examples include a golf swing, a diver jumping off a diving board, and a rocket taking off into space.
