How do I adjust the image rotation on this webpage?
  • MHB
  • Thread starter ranjan69
In summary, the conversation discusses MHB Rule #6, which states that teachers expect graded assignments to be the work of the student and not others. If a question is presented in a way that suggests it falls under this category, a moderator will close the thread. If a member is suspected of cheating, they will be banned and the thread may be shared with their institute. However, if evidence is provided that the problem is not from a graded assignment, the thread will be re-opened. The conversation also includes a question about the solution to a problem involving equilateral triangles and variables A, B, P, and Q. The image provided is rotated, cropped, and uploaded for better viewing.
ranjan69
Mathematics news on Phys.org
Hello, ranjan69!
MHB Rule #6 states:
MHB Rules said:
Teachers expect graded assignments to be the work of that student and not others. Therefore, MHB policy is not knowingly to help with questions in such assignments. If you present a question in such a way as to suggest that it falls in this category, a moderator will close the thread and explain why. The original poster can always PM the moderator to discuss the situation, but if the moderator is unconvinced, the thread will stay closed. When a moderator is certain that a particular member is trying to cheat, he will ban that member and remove the offending thread. Where possible, the moderator will notify the institute at which the member studies and provide a copy of the thread. This may sound harsh, but MHB places a high premium on academic honesty and integrity.
So, by our policy, I will close this thread, and await your PM for discussion of the matter.
The OP has graciously provided sufficient evidence to show that this problem is from an old test and is not part of a graded assignment. And so I have re-opened the thread accordingly. :D
phymat said:
I am unable to rotate this image clock wise.
I rotated, cropped and uploaded as an attachment. :)
FAQ: How do I adjust the image rotation on this webpage?
What is the concept of "distance" in scientific terms?
In science, distance is defined as the measurement of how far apart two objects are from each other in space. It is usually measured in units such as meters, kilometers, or miles.
What are some methods used to determine the distance between two objects?
Some methods used to determine distance include using rulers or measuring tapes for short distances, using instruments like rangefinders or sonar for longer distances, and using mathematical calculations based on the speed and time of an object's movement.
How do scientists use distance measurements in their research?
Distance measurements are crucial in scientific research as they provide important information about the location, size, and movement of objects. Scientists use distance measurements to study the positions of planets and stars, track the movement of animals, and monitor changes in the Earth's surface.
What is the difference between distance and displacement?
Distance is a scalar quantity that refers to the actual length of the path between two points. Displacement, on the other hand, is a vector quantity that refers to the shortest straight-line distance between two points and includes the direction of movement.
Why is it important to accurately determine the distance between objects?
Accurately determining distance is crucial in many fields of science, such as astronomy, geology, and physics. It allows scientists to make precise measurements, calculate important relationships between objects, and make informed predictions about future events.
