MHB How do I calculate a cumulative reducing percentage for forecasting?
  • Thread starter Thread starter gazzap
To calculate a cumulative reducing percentage for forecasting, start by determining the total score needed to meet the target percentage by year-end. For a target of 75% over 12 months, the total raw score required is 900. Subtract the cumulative score achieved so far from this total to find the score needed for the remaining months. Divide this figure by the number of remaining months to establish the average score required each month. The challenge lies in the variability of monthly scores, complicating the calculation of a precise formula.
gazzap
I have a maths problem that has confused me.
Each month I have a performance score. Month by month those scores are added together to make a cumulative score of the year to date.
There is a target (percentage) that must be achieved by the year end. Based on the current cumulative result I need to find what the result has to be in all of the remaining months in order to hit the target exactly.
For example
Month 1 result: 93 out of 100 (93%)
Month 2 result: 71 out of 100 (cumulative result is now 82%, 164 out of 200)
Target for year is 75%.
So, in the remaining 10 months, the result each month would have to be less than 75% (because it is currently 7% above the target). But what is the formula to calculate that figure?
Each month going forward, the real result will be entered, and of course this will have an effect on this figure.
I know the answer to the example is 73.9%, achieved purely using trial and error but I cannot create the formula to find the answer.
Using this figure I can see that the cumulative result changes more in the first month than the second and the second is more than the third and so on. ie the change is in ever decreasing amounts until the target is hit.
I don't know what the name of this maths problem is.
Can anyone help?
Mathematics news on Phys.org
For example
You need to use "raw" numbers rather than percentages but if that "out of 100" stays constant, then you can just treat the percentages as if they were "raw" numbers. If you want 75% 0ver the 12 months of the year, then you want a raw score if 0.75*1200= 900. You already have 93+ 71= 164, as you say. So you want a total of 900- 164= 736 over the next 10 months. That is an average of 73.6 for each month so you will want 73.6%, not 73.9%, of 100 each month.
Can anyone help?
Unfortunately the number isn't always out of 100 each month. I was using that to simplify the example so that the number would equal the percentage in the example but in reality the numbers are basically random. If I knew the total for the year was going to be out of 1200 then yes it would be far easier.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
