How do I calculate distance from acceleration and velocity?
In summary, an electric vehicle starts from rest and accelerates at a rate of ##2.0 \frac{m}{s^2}## until it reaches a speed of ##20 \frac{m}{s}##. It then decelerates at a rate of ##1.0 \frac{m}{s^2}## until it stops. The total time elapsed is 30 seconds and the total distance traveled is 300 meters.
Eclair_de_XII
1,083
91
"An electric vehicle starts from rest and accelerates at a rate of ##2.0 \frac{m}{s^2}## in a straight line until it reaches a speed of ##20 \frac{m}{s}##. The vehicle then slows at a constant rate of ##1.0 \frac{m}{s^2}## until it stops. (a) How much time elapses from start to stop? (b) How far does the vehicle travel from start to stop?"
##v = v_0+at##
##x-x_0=v_0t+\frac{1}{2}at^2##
Answer to (b): 300 m
(a)
##20\frac{m}{s} = 2\frac{m}{s^2}(t_1)##
##t_1=10s##
##0\frac{m}{s}=20\frac{m}{s}-1\frac{m}{s^2}(t_2)##
##-1\frac{m}{s^2}t_2=-20\frac{m}{s}##
##t_2=20s##
##t=t_1+t_2=10s+20s##
(b)
##x_1-0m=(0\frac{m}{s})(10s)+\frac{1}{2}(2\frac{m}{s^2})(10s)^2##
##x_1=100m##
##x_2-100m=(20\frac{m}{s})(20s)+\frac{1}{2}(-1\frac{m}{s^2})(20s)^2##
##x_2=100m+400m-200m=300m##
##x=x_1+x_2=100m+300m ≠ 300m##
##v = v_0+at##
(a)
##t_1=10s##
##t_2=20s##
(b)
##x_1=100m##
x_2 is the position, not the displacement during the second stage of motion.
you have mistaken in attempting question b
only x2-100 gives the displacement in the time of disceleration and x2 is the total displacement and you calculated it has 300m(correct)
With a problem like this (two different acclerations) it can be useful to draw a graph of the motion: velocity against time. The displacement is then the area under the graph. It helps you visualise the motion and can prevent you from plugging the wrong numbers into your equations.
So you're saying that x2 = x1 + x3, where x3 is some arbitrary distance between the end of x1 and x2? Then that would mean...
##x_2-100m=(20\frac{m}{s})(20s)+\frac{1}{2}(-1\frac{m}{s^2})(20s)^2 = x_1+x_3-x_1 =x_3##
##x_3=(20\frac{m}{s})(20s)+\frac{1}{2}(-1\frac{m}{s^2})(20s)^2=400m+(-200m)=200m##
##x_2=x_3+x_1=200m+100m=300m##
Thanks, guys.
Related to How do I calculate distance from acceleration and velocity?
1. How do I calculate distance using acceleration and velocity?
To calculate distance from acceleration and velocity, you can use the formula: d = v0t + 1/2at2 where d is the distance, v0 is the initial velocity, t is the time, and a is the acceleration.
2. Can I calculate distance with only acceleration and velocity?
Yes, you can calculate distance using only acceleration and velocity as long as you have the initial velocity and the time. However, you will need additional information such as the displacement or the final velocity to accurately calculate the distance.
3. How do I find the distance if I only have the final velocity?
If you only have the final velocity, you can use the formula: d = (v02 - v2)/2a where d is the distance, v0 is the initial velocity, and a is the acceleration.
4. What units should I use when calculating distance from acceleration and velocity?
The units used for distance will depend on the units used for velocity and acceleration. For example, if velocity is in meters per second (m/s) and acceleration is in meters per second squared (m/s2), then distance will be in meters (m).
5. Can I use this formula to calculate distance for any type of motion?
Yes, this formula can be used to calculate distance for any type of motion as long as the motion is constant. If the motion is not constant, then you will need to use more complex equations to accurately calculate the distance.
