How do I calculate the mass density, given the mass?
In summary, the conversation discusses finding the mass density as a function of position and the total mass of an object given the mass as a function of position. It also delves into the concept of probability density and normalizing it to make it a valid probability function. The final solution is to re-write the probability density function as a function of one variable and normalize it.
silmaril89
86
Let's say you have the mass of an object as a function of position, how would I go about finding the mass density as a function of position? I want a general answer, one that doesn't assume the mass has uniform density (that would be trivial).
As an example, can you solve this?
Say you have a ring of radius 1 with its center at the origin of a cartesian coordinate system. You are given that the mass [itex] M(x,y) = \frac{4}{\pi} x y [/itex]. Find the mass density of the ring.
The reason I want to do this, is to find the total mass of some object given the mass as a function of position, but in order to do the necessary integral it seems I need the mass density.
Any help would be greatly appreciated
Mass as a function of position doesn't make much sense. (At least not for a continuous distribution.) Given the mass density as a function of position, you can integrate to find the total mass. Are you sure that's not what you are thinking of?
I'm sure. I understand how it doesn't make much sense to think of mass as a function of position. I have another question that led me to this one. The real question is about probability density. I have that the probability of some thing occurring to be [itex] P(x,y) = \frac{4}{\pi} x y [/itex], but I want the total probability of this thing occurring if I don't know x or y. I figured I need the probability density, how would I get this?
Your analogy is correct- it would only make sense if P is the probability density. In the same way that a point can't have a (finite) mass, one single event out of an infinite number of possibilities cannot have a (finite) probability. You can, however, specify the amount of mass in an infinitesimal volume, dm = density*dV, and you can specify the probability of an event occurring in the infinitesimal range of a continuous space of possible outcomes.
eg. if P is the actual probability then the outcome (1,1) has a probability of 4/pi of happening, which is greater than 1 and completely nonsensical.
Yes, but the specification is that P(x,y) is only valid on a ring of radius 1 (i.e. (1,1) is not a valid point).
Basically, I have the probability of an event occurring being equal to [itex] P(x,y) = \frac{4}{\pi} x y [/itex], but the issue is that I don't know what the probability for the event to occur if the position (x,y) is random and only on a ring of radius 1. What can I do?
That's a fair point, but here's another reason P cannot be a probability- consider two arbitrarily close points in this space- (x,y) and (x+dx, dy). The probabilities of each of these two events occurring are P(x,y) and P(x+dx,dy), and so the probability of either occurring is P(x,y) + P(x+dx,y). Now let's add a third probability- P(x+2*dx, dy). The probability of any of these three occurring is the sum of each of the probabilities.
This becomes problematic very quickly because we are adding together finite (nonzero) quantities, but we haven't specified how small dx is- it can be so arbitrarily small that this sum contains infinitely many nonzero terms - leading to an infinite probability - within a finite space, or region of possible outcomes. To deal with this you need to multiply P by the area element dxdy to keep the probability within an infinitely small possibility space infinitely small.
One more reason might help explain this- the units don't make sense. If x spans some range of possibilities, then it could have a dimension, but the probability must be dimensionless. For example, if x and y are lengths, say, distance from the bullseye of an archery board, then P has units of m^2. But expressing a probability in units of area doesn't make sense.
The easiest thing to do will be to re-write the PDF as a function of one variable, e.g. P(θ). Btw, your function cannot be a valid PDF over the whole unit circle because it has negative values.
[tex] P(\theta) = \frac{4}{\pi} \mid \sin \theta \cos \theta \mid [/tex]
In this case the probability that the event will occur in the range (θ1,θ2) is
∫P(θ)dθ from θ1 to θ2
P(θ) is the PDF, not the probability.
There is one more issue, P(θ) is not normalised.
Normalization is tough, but I just divided by ([itex] \theta_2 - \theta_1 [/itex]), but something tells me that isn't right.
Wolfram alpha is a great tool for this stuff
http://www3.wolframalpha.com/Calculate/MSP/MSP10821a2c28b265g1d9a800005305h834i2614295?MSPStoreType=image/gif&s=26&w=167&h=35
P(θ) = (1/2)*|sin(θ)cos(θ)| should be correct
Yes, that is non-negative everywhere and integrates to 1 over -π < θ < π.
Related to How do I calculate the mass density, given the mass?
1. How do I calculate mass density?
Mass density is calculated by dividing the mass of an object by its volume. The formula for mass density is mass/volume.
2. What units are typically used for mass density?
The most commonly used units for mass density are grams per cubic centimeter (g/cm3) or kilograms per cubic meter (kg/m3).
3. How do I convert mass density to different units?
To convert mass density to different units, you can use conversion factors. For example, to convert from g/cm3 to kg/m3, multiply the value by 1000. You can also use online conversion calculators for convenience.
4. Is mass density the same as density?
Yes, mass density and density are often used interchangeably and refer to the same physical quantity. However, mass density specifically refers to the mass of an object per unit volume.
5. How is mass density used in science?
Mass density is used in various scientific fields, including physics, chemistry, and geology. It is used to describe the density of materials, determine the composition of substances, and calculate the buoyancy of objects in fluids.
  • Other Physics Topics
