How do i calculate this -- Using numerous parabolic mirrors to focus light
In summary: H_2O is the number of molecules of water vapor, nH is the number of molecules of hydrogen, and so on.So you need\dot Q = \frac{A_m}{{n_{H_2 O} \cdot R}}where R is the gas constant.So the energy you need to focus the light onto a mutual point is\dot Q = \frac{A_m}{{n_{H_2 O} \cdot R}} \cdot \frac{k}{{T - T_0}}In summary, you will need approximately 3 square meters of mirrors to focus the light onto a mutual point
Ali Yuksel
So for my semester project, I was given something that most scientists think is "impossible". Using numerous parabolic mirrors, i need to focus the reflected light onto a mutual point, and achieve a temperature of about 3000*C. Why 3000? That is when thermal decomposition of H2O occurs. What i want to calculate first, is the amount of energy i will need to make this happen. Am i supposed to go with Q=MCdT? The specific heat of H2O changes a lot after so many degrees. My idea was to first calculate from room temp to 100*C, then calculate from 100*C to the degree where the specific heat starts to change again, and then I am completely lost, because what specific heat would i use to calculate the rest? Please someone give me a magical equation to solve all my problems:S
Science news on Phys.org
I can't help with expertise nor magic, but your project caught my eyes with interest. I'm attaching a link to a tech document from Chromalox, an industrial heat corporation. It doesn't offer details up to 3000 C, and yet there seems to be valuable info regarding superheating steam (that's what I searched on). Have you seen this or similar? I smiled when I read a comment in it about "always allow 20% for unknown loss" oo)
http://www.chromalox.com/...information/...Heater-Selection-Steam-Heating.pdf
What kind of vessel would you contain the water in? What's the part the scientists think is impossible?
The link is broken.
Every temperature range has its value for heat capacitance, and I'm sure there are databases or publications covering that.
I wouldn't be worried about the water so much. Whatever you use as container, at 3000°C it will glow white and lose significant power to the environment. You will need a really powerful light source to counter that.
This is not true. Water dissociates at lower temperatures. 3000 is nothing but an arbitrary number.
I'm not sure of the validity of this but as a stab in the dark...
Perhaps you could assume that the object being heated glows white hot and behaves like a black body. Then use Boltzmann's law to work out the power loss at 3000C.
http://en.wikipedia.org/wiki/Stefan–Boltzmann_law
Suppose the object is a 1cm cube and has a surface area of 6cm^2. The power loss would be around..
5.6*10^-8 * 3000^4 * 6 * 10^-4 = 2.7KW
Solar power being around 1000W/m^2 at mid day on a cloudless day. So I reckon you will need around 3-4 square meters of mirrors at least?
Is it possible to focus a home made mirror that large down to such a small area?
This old article has some comments on that ...
http://amasci.com/amateur/mirror.html
It is possible. The maximal temperature you could reach via mirrors is the same as the temperature of the surface of the sun, and you reach it if the object "sees" the sun in every direction. That doesn't make it easy, however.
That's too simple because,
1. C changes with Temperature
2. you also need energy for the thermal decomposition and
3. you would neglect the loss of energy due radiation and thermal conduction
Let's start with the energy collected by the mirrors:
[tex]\dot Q_{in} = A_m \cdot E_0[/tex]
where Am is the total area of the mirrors and Eo the local solar constant.
The heat loss by radiation is
[tex]\dot Q_{rad} = A_c \cdot \sigma \cdot T^4[/tex]
where Ac is the area of the collector.
The heat loss by thermal conduction is
[tex]\dot Q_{cond} = k \cdot \left( {T - T_0 } \right)[/tex]
Now it's going to be interesting. The heat required for heating and thermal decomposition of water is the difference of the formation enthalpies. If water with the Temperature To flows into the reactor and a mixture of water vapor, hydrogen and oxygen with the temperature T comes out the corresponding change of enthalpy is
[tex]\dot Q_H = \dot n_{H_2 O} \cdot \Delta _f H_{H_2 O} \left( T \right) + \dot n_{H_2 } \cdot \Delta _f H_{H_2 } \left( T \right) + \dot n_{O_2 } \cdot \Delta _f H_{O_2 } \left( T \right) - \dot n \cdot \Delta _f H_{H_2 O} \left( {T_0 } \right) [/tex]
The stoichiometry of the reaction
[tex]H_2 O \Leftrightarrow H_2 + {\textstyle{1 \over 2}}O_2[/tex]
results in the following amounts of substances
[tex]\dot n_{H_2 O} = \left( {1 - x} \right) \cdot \dot n[/tex]
[tex]\dot n_{H_2 } = x \cdot \dot n[/tex]
[tex]\dot n_{O_2 } = {\textstyle{1 \over 2}}x \cdot \dot n[/tex]
Where
[tex]\dot n = \frac{{\dot m}}{{M_{H_2 O} }}[/tex]
is the total flow into the reactor.
The degree of conversion x can be obtained from the equilibrium constant
[tex]K = \frac{{x_{H_2 } \cdot \sqrt {x_{O_2 } } }}{{x_{H_2 O} }}[/tex]
The amounts of substances give the mole fractions
[tex]x_{H_2 O} = \frac{{2 - 2 \cdot x}}{{2 + x}}[/tex]
[tex]x_{H_2 } = \frac{{2 \cdot x}}{{2 + x}} [/tex]
[tex]x_{O_2 } = \frac{x}{{2 + x}}[/tex]
resulting in
[tex]K^2 = \frac{{x^3 }}{{\left( {2 + x} \right) \cdot \left( {1 - x} \right)^2 }}[/tex]
The last step is the calculation of the equilibrium constant
[tex]\ln K = - \frac{{\Delta _r G}}{{R \cdot T}}[/tex]
from the change of Gibbs free energy:
[tex]\Delta _r G\left( T \right) = \Delta _r H\left( T \right) - T \cdot \Delta _r S\left( T \right) [/tex]
Now T, To, Am, Ac and dm/dt need to be adjusted in order to balance the sum of all heat flows out:
[tex]\dot Q = \dot Q_{in} \left( {A_m } \right) - \dot Q_{rad} \left( {A_c ,T} \right) - \dot Q_{cond} \left( {k,T,T_0 } \right) - \dot Q_H \left( {\dot m,T,T_0 } \right) = 0[/tex]The required thermodynamic data can be obtained here:
http://webbook.nist.gov/cgi/cbook.cgi?ID=C7732185&Units=SI&Mask=2#Thermo-Condensed
http://webbook.nist.gov/cgi/cbook.cgi?ID=C7732185&Units=SI&Mask=1#Thermo-Gas
http://webbook.nist.gov/cgi/cbook.cgi?ID=C1333740&Units=SI&Mask=1#Thermo-Gas
http://webbook.nist.gov/cgi/cbook.cgi?ID=C7782447&Units=SI&Mask=1#Thermo-Gas
PS: How can I limit the formulas to a reasonable size?
Its not the number which water dissociates, different percentages of H2O dissociate at various temperatures. 3000 is my goal, as i can get a decent 40% decomposition.
We haven't decided on what type of vessel to contain the H2O in yet, but we are counting for an 80% heat loss. With all the losses at such high temperatures, rather then working out every loss, we concluded on a 20% efficiency.
How are you going to separate the products of the reaction?
Probably il make the separation through electrolysis. I don't know what anode and cathode i will use yet, but i will def let you know when i figure that out.
Also..I will be giving the current using solar energy as well.
Electrolysis can split water into hydrogen and oxygen (you already planned the thermal decomposition for this step) but not for separation of a gas mixture. Or do you mean using ion conductors?
3000 C, huh? That's pretty hot. How do you intend to hold the H2O in place while you heat it up? Are you going to hold it in a pressurized tungsten crucible? The pressure will get pretty high
Certainly easier to do that than build a solar furnace :-)
yes electrolysis can split water into hydrogen and oxygen but once the split occurs the oxygen and hydrogen atoms go to the anode and cathode individually..Now, after the split is done using thermal decomposition, even with small current, the atoms will go in there directions to the anode and cathode. Think of it as using thermal decomposition to give a rapid boost to the electrolysis. How do i intend to hold it in place? no clue on that yet. I am currently working on the mathematical parts. All i know now is that i will make my focal point very tiny and will be using 100grams of H2O. My intention isn't to get 100% decomposition. My goal at the end is to strictly use solar resources to get hydrogen. At the end of the day, no matter how slow, this is 100% effeciency. Whats the loss?
I'll go with, "one-hundred grams of water." (Is this a trick question?) :confused:
It's interesting to follow your design progress, Ali. "Good luck is the residue of preparation."
That is a fine goal, but there is no need to re-invent the wheel.This is already being done on an industrial scale in Spain. Perhaps you should study their approach and other research in this field.
CWatters earlier calculated the power loss of 2.7 kW for 1 cubic cm of water. You are planning to use 100 cubic cm, so your power loss is going to be roughly 60 kW, which means you need to collect solar energy from at least 120 square meters. Do you have budget for this sort of project?
Hydrogen and oxygen do not go to cathode and anode. They are produced there.
You are confusing atoms with ions. Atoms are not charged and will therefore not be affected by the electrodes. If you want to separate hydrogen and oxygen by electric or magnetic fields you would need to heat them up to plasma state. At normal pressure 3000 K wouldn't be sufficient this purpose.
DrStupid said:
Q˙H=n˙H2O⋅ΔfHH2O(T)+n˙H2⋅ΔfHH2(T)+n˙O2⋅ΔfHO2(T)−n˙⋅ΔfHH2O(T0)
Would you be able to explain this equation a bit more, I am kind of lost with the variables..
Thanks
Why are you using deltaF? isn't that the enthalpy for saturated liquid? shouldn't deltaG be used instead? where that would stand for saturated vapor?
DeltaF is the enthalpy of formation. The equation describes the heat required for increase of temperature and thermal decomposition of water according to the (simplified) chemical reaction given above.
DeltaG is the change of Gibbs free enthalpy and it is used for the equilibrium constant.
Related to How do i calculate this -- Using numerous parabolic mirrors to focus light
1. How do I calculate the focal length of a parabolic mirror?
The focal length of a parabolic mirror can be calculated using the formula f = D^2/16c, where f is the focal length, D is the diameter of the mirror, and c is the depth of the parabola. This formula assumes that the parabola is a perfect shape. If the parabola is not perfect, the focal length can be approximated by measuring the distance from the center of the mirror to the point where the reflected light converges.
2. How do I determine the spot size of the focused light using multiple parabolic mirrors?
The spot size of the focused light can be calculated by multiplying the diameter of the mirror by the focal length and dividing by the distance between the mirrors. For example, if you have two mirrors with a diameter of 10 cm and a focal length of 20 cm, placed 50 cm apart, the spot size would be (10*20)/50 = 4 cm. This formula assumes that the mirrors are perfectly aligned and that there is no overlap between the mirrors' focal points.
3. How do I calculate the total light intensity when using multiple parabolic mirrors?
The total light intensity can be calculated by multiplying the light intensity of each individual mirror. For example, if you have three mirrors with light intensities of 1000 lumens, 1500 lumens, and 2000 lumens, the total light intensity would be 1000*1500*2000 = 3,000,000 lumens. This formula assumes that the mirrors are perfectly aligned and that there is no overlap between the mirrors' focal points.
4. How do I determine the optimal placement of the parabolic mirrors for maximum light concentration?
The optimal placement of the parabolic mirrors for maximum light concentration depends on the specific application and desired outcome. In general, the mirrors should be placed in a way that minimizes shadowing and overlap of the focused light. Additionally, the mirrors should be angled in a way that directs the focused light towards the desired target. Performing simulations or experiments with different placements can help determine the most optimal configuration.
5. How do I account for loss of light due to imperfections in the parabolic mirrors?
The loss of light due to imperfections in the parabolic mirrors can be accounted for by adjusting the light intensity of each mirror. For example, if one mirror has a lower light intensity due to imperfections, its light intensity can be increased to compensate for the loss of light. Additionally, using high-quality mirrors and regularly maintaining and calibrating them can help minimize light loss due to imperfections.
  • Other Physics Topics
