How do I change this integral limit from x to t?
PainterGuy
How do I change the integral limit from x to t.
I've included the equations in main posting. Thanks.
Hi,
It's not a homework problem. I was just doing it and couldn't find a way to change the integral limit from "x" to "t". I should end up with kinetic energy formula, (1/2)mv^2. I've assumed that what I've done is correct. Thank you!
Edit:
"E" is work done.
In the very last step of your derivation, where you change the variable of integration from ##dx## to ##dv## the integral limit has to change but not from ##x## to ##t## but from ##x ## to ##v_f## that is the final velocity. Also the lower limit has to change from## 0## to ##v_i## that is the initial velocity.
P.S the two last steps where you pull out ##v## out of the integral, is not a correct thing to do. Velocity ##v## is a function of time and displacement ##x## is also a function of time, so there is an implicit equation between v and x, that is essentially velocity v is a function of distance x that is ##v=v(x)## so it just can't be taken out of the integral.
To see this more clearly, take the case where the force F is constant, hence we have constant acceleration ##a## and the velocity ##v(t)=at## (assuming zero initial velocity). But it is also $$x(t)=\frac{1}{2}at^2\Rightarrow t=\sqrt{\frac{2x}{a}}$$ and thus replacing this t in the first equation we get $$v(x)=a\sqrt{\frac{2x}{a}}=\sqrt{2ax}$$
You have two problems.
First you can't write ##\int_0^x F\,dx##. It doesn't mean anything, because you are using the same symbol for integration variable and limit.
So instead, use ##x'## as your integration variable: ##\int_0^x F\,dx'##.
Secondly, you can't move ##v## outside the integral as you do in the 2nd last step, because it changes with the integration variable ##x'##.
The development you want is:
m\int_0^x \frac{dv}{dt}dx'
=m\int_{x'=0}^{x'=x} \frac{dx'}{dt}dv
=m\int_{v=v_0}^{v=v_x} v\,dv
where ##v_0,v_x## are the velocities at locations 0 and ##x##.
The integration is then straightforward.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
