How do I convert meters cubed to cubic centimeters?
  • Thread starter Wanting to Learn
  • Tags
    Volume
In summary, the conversation is about a student struggling with a physics problem and trying to figure out how to get the correct answer, while their teacher emphasizes the importance of understanding how to use the website. The student asks for help with a problem involving finding the volume of a sample of copper, and after some calculations, realizes they need to convert from meters cubed to centimeters cubed. They receive guidance on how to do this by using a conversion factor and manipulating algebraic expressions.
Wanting to Learn
This comes from the Intro Homework to my AP Physics 1 class.
The teacher said that it is more important to figure out how to use the website than get the correct answers to the questions. However, I want to know how to get the correct answer, especially since I took chemistry last year and think I should know this.
I'm not certain, but I might just be missing a small step in the calculations.
Problem Statement, Variables and Given Data:
What is the volume V of a sample of 2.70 mol of copper?
The atomic mass of copper (Cu) is 63.5 g/mol.
The density of copper is 8.92×103kg/m3.
Express your answer in cubic centimeters to 3 significant figures.
Attempt at the Solution:
I think I need to multiply and cancel units, however I am not sure what I'm missing.
(I do know how to use the proper number of significant figures.)
2.70mol * 63.5g/mol = 171.45g
8.92×103kg * 1000g/1kg = 8.92 * 106g
(Should I convert the 171.45g to kg here instead?)
*171.45g * 8.92 * 106g/m3 = 1,529,334,000g2/m3
*I am not sure where to go from here in order to get to just meters cubed, assuming that is what I should be looking for.
*update of the two lines above:
I just realized that if I put m3/g then the grams would cancel, and got this:
171.45g * 1m3/8.92 *106g = 0.00001922m3
Now I need to convert that to cm3. I always get confused when doing this, because of the 3. How exactly do I do this last step? I know that I should know this more basic part but I want understand exactly what to do with it.
I tried and the answer I got was one decimal place off; I got 1.92 instead of 19.2cm3.
I did put "volume of 2.70mol Cu" into Wolfram Alpha and got an answer, however I want to know how to get it on my own. Did I miss or do something wrong in the calculations I did, or am I missing something not expressly stated in the question?
Thank you in advance for your help.
If you are going to put mass in the denominator (103 kg or 106 grams), then you also need to put the corresponding value (8.92) in the denominator.
Oops, I did that correctly in my calculation (on a different piece of paper) but typed it in wrong, I just fixed it (edited my original post).
Thank you for pointing that out.
It's good that you followed the units. They're one of the most reliable signs telling you if you're on the right path or not.
It'd be even better if you first manipulated algebraic expressions before trying to plug in the numbers.
Density is mass over volume:
##\rho = \frac{m}{V}##
So if you need to find volume:
##V = \frac{m}{\rho}##
You want to convert metres to third power into centimetres to the same power. Just follow these three steps.
1. How many centimetres are there in a metre? 100
2. What is the power? 3
3. Raise 100 to the power of 3
Answer 1 m^3= 10^6 cm^3
Conceptually, imagine you have a physical cube 1 m long, 1 m wide, and 1 m tall. You're trying to figure out how many 1 cm^3 cubes (1 cm long, wide, and tall) are needed to build that 1 m^3 cube.
So you take the 1 cm^3 cube and stack 100 of those next to another (since there is 100 cm in a metre) - this gives you a line 1 metre long, but still 1 cm wide and tall. So you stack 100 such lines on top of another, to get a wall of 1 m length and height, but still 1 cm wide (by this point you've used 100x100 small cubes). You need 100 such walls next to one another to get a full 1m^3 cube. You've used 100x100x100 of the 1 cm^3 cubes, i.e. there's 10^6 cm^3 in 1 m^3.
And if you were to convert something like centimetres squared into metres squared:
1. How many metres in a centimetre? 0.01
2. What is the power? 2
3. Raise 0.01 to the power of 2
Answer 1 cm^2 = 10^-4 m^2
Great. Now to convert meters3 to cm3.
Think of it like this: 1 m = 100 cm. So we can make a conversion factor by dividing both sides by (1 m), and we get this:
$$1 = \frac {100 ~ cm} {1 ~m}$$
You could also divide both sides by (100 cm) and get this: $$\frac {1 ~ m} {100 ~cm} = 1$$
Note that 1 is dimensionless. You can multiply or divide anything by dimensionless 1, without changing the value.
So if you have something that is in meters3, just multiply by (100 cm) / (1 m), and you need to do that three times to cancel out m3. Then you will have cm3.
Related to How do I convert meters cubed to cubic centimeters?
1. How do you calculate volume given moles?
To calculate volume given moles, you can use the formula V = nRT/P, where V is the volume in liters, n is the number of moles, R is the ideal gas constant, T is the temperature in Kelvin, and P is the pressure in atmospheres.
2. What is the ideal gas constant?
The ideal gas constant, also known as the molar gas constant, is a physical constant that relates the amount of substance in moles to the pressure, volume, and temperature of an ideal gas. Its value is approximately 0.0821 L·atm/mol·K.
3. How does temperature affect the volume given moles?
According to the ideal gas law, as temperature increases, the volume of a gas also increases. This is because the particles in the gas have more kinetic energy and move faster, resulting in a larger volume. Therefore, the volume given moles will increase as the temperature increases.
4. Can you explain the units used in the formula for calculating volume given moles?
The units used in the formula V = nRT/P are: V (volume) in liters, n (moles) in moles, R (ideal gas constant) in L·atm/mol·K, T (temperature) in Kelvin, and P (pressure) in atmospheres. It is important to make sure all units are consistent when using this formula.
5. What is the difference between molar volume and volume given moles?
Molar volume is a constant value representing the volume occupied by one mole of an ideal gas at standard temperature and pressure (STP). On the other hand, volume given moles is calculated using the ideal gas law and can vary depending on the number of moles, temperature, and pressure. Molar volume is a fixed value, while volume given moles can change depending on the conditions.
