HACRS4
- 3
I am trying to create a code, in Matlab, that will describe the geometry of a PARSEC airfoil. The x coordinates for the upper and lower surfaces of the airfoil shape simply run from 0 to 1 (for a unit chord length). The z-coordinates (that describe the shape) are given by:
z_upper = sum (a_n * x ^ ((n-1) / 2) )
where the summation occurs over n = 1 to n =6. The coefficient a_n is determined by solving a system of linear equations - I think I have done this correctly.
The lower surface z-coordinates are similarly defined by with a different set of coefficients.
The way I have approached the problem is to try and create a matrix with 6 columns (for n = 1:6) and as many rows are there are x-coordinates. A vector containing all of the z-coordinates is then found by summing the values across each of the 6 columns for each row.
However, Matlab is only returning a 7x6 matrix instead of a matrix with as many rows are there are x-coordinates. It is also returning an 'index out of bounds' when creating the vector of z-coordinates - I think this is just because the defined matrix is too small.
My apologies if the solution is a simple one, I am new to coding.
for n = 1:6
z_upper = Ʃ a_n * x ^ ((n-1)/2)
% Test Values
x(1) = 0.01;
x(2) = 8;
x(3) = 12;
x(4) = 0.43;
x(5) = 0.12;
x(6) = -0.8;
x(7) = 0.23;
x(8) = -0.020;
x(9) = 0.1;
x(10) = -0.004;
x(11) = 0.003;
x(12) = 0.0030;
% x-coordinate range
x_coord = 0:0.01:1;
% upper surface coefficients (x_u = a_n)
% Ax = B
A_U = [ 1 1 1 1 1 1 ; x(4)^(1/2) x(4)^(3/2) x(4)^(5/2) x(4)^(7/2) x(4)^(9/2) x(4)^(11/2); 1/2 3/2 5/2 7/2 9/2 11/2;... (1/2)*x(4)^(-1/2) (3/2)*x(4)^(1/2) (5/2)*x(4)^(3/2) (7/2)*x(4)^(5/2) (9/2)*x(4)^(7/2) (11/2)*x(4)^(9/2);... -(1/4)*x(4)^(-3/2) (3/4)*x(4)^(-1/2) (15/4)*x(4)^(1/2) (35/4)*x(4)^(3/2) (63/4)*x(4)^(5/2) (99/4)*x(4)^(7/2);... 1 0 0 0 0 0];
B_U = [x(10) + (1/2)*x(12); x(5); tan((2*x(2) - x(3))/2); 0; x(6); sqrt(x(1))];
x_u = A_U\B_U;
% z (upper surface) coordinates
% z_upper = sum ( (x_u(n) * x_coord(n-1/2) )
for j = 1:6
for i = 1:length(x_coord)
z_mat(i,j) = x_u(j) * x_coord(i) ^ ((j-1)/2);
z_upper(i) = sum(z_mat(:,(i)));
end
end
