How do I derive and solve the equation for the athlete's running speed?
In summary: Since the last equation is the same, that means you have: $$v(2v-5)\frac{80}{v} = (2v-5)\frac{80}{v}v = 80$$= \(v(2v-5)\frac{80}{v} = (2v-5)\frac{160}{4} = 80\)= \(160v^2 - 400v + \frac{16v^2-40v}{3} = 80\)
Simonio
I'm having problems getting going on the following question, any help appreciated:
As part of his training an athlete usually runs 80 km at a steady speed of \(v\) km h. One day he decided to reduce his speed by 2.5 km h and his run takes him an extra 2h 40 mins.
Derive the equation \(\frac{80}{v}+ \frac{8}{3} = \frac{160}{2v-5}\) and solve it to find the value of \(v\).
Mathematics news on Phys.org
where is the problem deriving or solving
Hi Simonio!
Suppose we define $t$ to be the time it takes the athlete to run 80 km at a speed of $v$ km/h.
Can you set up the equations that correspond to the run times?
I like Serena said:
Hi Simonio!
Well I think I can say that \(t\)= \(\frac{80}{v}\) and with the slower speed \(t\) = \(\frac{80}{v-2.5}\) not sure of next step
Good! :)
With the slower speed it takes 2h40 longer, which is $2\frac 2 3$ hours.
So it should be:
$$t + 2\frac 2 3 = \frac{80}{v-2.5}$$
Can you combine the 2 equations and eliminate $t$?
I like Serena said:
Good! :)
So it should be:
OK-you've given me a good hint there!
so: \(\frac{80}{v} + \frac{8}{3} = \frac{160}{2v-5}\)
Not sure about the next bit: do I multiply throughout by \(2v-5\)?
That would make: \((2v-5) \frac{80}{v} + (2v-5) \frac{8}{3} = 160\)
Think I'm on the wrong track
Good!
You're right on track.
Continue by multiplying throughout by $v$.
I like Serena said:
Good!
Do you mean multiply by \(2v-5\)?
You already did that.
But you're still left with $v$ in a denominator.
Then I get: \(v(2v-5)\frac{80}{v}\ +v(2v-5)\frac{8}{3} = 160v\)
= \(80(2v^2-5) + (2v^2-5)\frac{8}{3}\ = 160v\)
= \(160v^2 - 400v + \frac{16v^2-40v}{3}\ = 160v\)
Not sure whether I've lost the plot here!
When you multiply $v(2v-5)$, you should get $(2v^2-5v)$ instead of $(2v^2-5)$.
That is because generally $a(b+c)=ab+ac$.
You can check this with for instance $4(2+3)$.
Furthermore, you can write:
$$v(2v-5)\frac{80}{v} = (2v-5)\frac{80}{v}v = (2v-5)80$$
That is because if you first divide by $v$ and then multiply by $v$ the effects cancel.
FAQ: How do I derive and solve the equation for the athlete's running speed?
What is the quadratic equation?
The quadratic equation is a mathematical formula used to find the roots of a quadratic polynomial. It is written in the form ax^2 + bx + c = 0, where a, b, and c are constants and x is the variable.
Why is it important to know how to derive the quadratic equation?
Deriving the quadratic equation helps us understand the relationship between the coefficients and roots of a quadratic polynomial. It also allows us to solve more complex equations and make predictions in various fields such as physics and engineering.
What is the process of deriving the quadratic equation?
The process of deriving the quadratic equation involves using the method of completing the square to solve for the roots of a quadratic polynomial. This involves manipulating the equation to get it in the form (x + p)^2 = q, where p and q are constants.
Can you explain the steps of completing the square in deriving the quadratic equation?
Sure. The first step is to move the constant term (c) to the right side of the equation. Then, divide the entire equation by the coefficient of x^2 (a). Next, add the square of half the coefficient of x (b/2a)^2 to both sides of the equation. This will result in a perfect square on the left side, which can be factored into (x + b/2a)^2 = (c/a) + (b/2a)^2. Finally, take the square root of both sides and solve for x.
Are there any shortcuts for deriving the quadratic equation?
Yes, there is a formula called the quadratic formula that can be used to directly find the roots of a quadratic polynomial without having to complete the square. It is written as x = (-b ± √(b^2 - 4ac)) / 2a. This formula can be derived from the quadratic equation itself.
