How do i determine if a sequence converges or diverges
  • MHB
  • Thread starter ineedhelpnow
  • Tags
    Sequence
In summary, the first sequence converges to 0 as the limit of the sequence approaches infinity, while the second sequence also converges to 0 as the limit of the sequence approaches infinity. This is determined by comparing two sequences term-by-term and using the Squeeze theorem. However, it can be difficult to determine convergence in practice and it is important to avoid speaking of infinity as a number.
ineedhelpnow
651
like these problems for example. if it converges then I am supposed to find the limit.
$a_n=\frac{\sin\left({2n}\right)}{1+\sqrt{n}}$
$\left|\sin\left({2n}\right)\right| \le 1$
$a_n=\frac{(-3)^n}{n!}$
$\left|a_n\right| > 0$
We know that : $|\sin(2n)| \leq 1 \Rightarrow -1 \leq \sin(2n) \leq 1 \Rightarrow -\frac{1}{1+ \sqrt{n}} \leq \frac{\sin(2n)}{1+ \sqrt{n}} \leq \frac{1}{1+ \sqrt{n}}$
Now,we take the limit $n \to +\infty$ and we have:
$$\lim_{n \to +\infty} -\frac{1}{1+ \sqrt{n}} \leq \lim_{n \to +\infty} \frac{\sin(2n)}{1+ \sqrt{n}} \leq \lim_{n \to +\infty} \frac{1}{1+ \sqrt{n}} \Rightarrow 0 \leq \lim_{n \to +\infty} \frac{\sin(2n)}{1+ \sqrt{n}} \leq 0$$
So,according to the Squeeze theorem:
$$\lim_{n \to +\infty} \frac{\sin(2n)}{1+ \sqrt{n}}=0$$
Therefore,the sequence converges to $0$.
so if it were $\infty$ it would diverge?
Yes..
if you take the limit of the second one you get 0. so converges?
$$\frac{3^n}{n!}=\frac{3}{1} \cdot \frac{3}{2} \cdot \frac{3}{3} \cdot \frac{3}{4} \cdot \frac{3}{5} \cdots \frac{3}{n} \leq \frac{3}{1} \cdot \frac{3}{2} \cdot \frac{3}{3} \cdot \frac{3}{4} \cdot \frac{3}{4} \cdots \frac{3}{4}=3 \cdot (\frac{3}{4})^{n-3} $$
$$ \text{As } n \to +\infty , (\frac{3}{4})^{n-3} \to 0 \text{ and } \frac{3^n}{n!}>0 \ \text{ so,according to the Squeeze theorem: } \frac{3^n}{n!} \to 0$$
why is it to 3/4
never mind. i understand
ineedhelpnow said:
why is it to 3/4
We take this number,because we know that: $\displaystyle{ a^n \to 0 }$,as $\displaystyle{n \to +\infty }$,when $|a|<1$ and $\frac{3}{4}$ satisfies this condition..
Only if you can show that your expression is GREATER than the quantity that $\displaystyle \begin{align*} \to \infty \end{align*}$...
what do you mean?
Basically, the idea is to compare two sequences "term-by-term".
One caveat, one may have to go out quite a few terms to get "dominance" of one sequence over another. But discarding any finite amount of "initial terms" does not affect the behavior of the sequence "at infinity".
Now if for some $N$, we have for EVERY $n > N$, $b_n > a_n \geq 0$, and the sequence $\{b_n\}$ converges, then the $a_n$ are "trapped" between the limit of the $b_n$ and 0 (as $n$ "approaches infinity", that is to say, is sufficiently large).
This, by itself, doesn't mean $\{a_n\}$ converges, it might just "oscillate wildly" between the limit for the $b_n$ and 0.
If, however, the $b_n$ converge to 0, the $a_n$ have no choice in the matter.
Now if the $a_n$ fail to converge, the behavior of the $b_n$ will be "even worse" (it can't get better, because the $a_n$ are "keeping the $b_n$ away" from any potential limit).
Calculus teachers (sly devils that they are), don't want to make this easy for you, so they typically want you to look at:
$a_n = \dfrac{c_n}{d_n}$
where both "top and bottom" behave the same "at infinity" (both go to 0, or both become infinitely large), and it becomes a matter of "practice" recognizing which "side" wins, and often, you have to resort to some OTHER sequence for comparison.
I wish I could tell you "which other sequences" to use, but this is almost ALWAYS done on a case-by-case basis.
Of course, teachers "rig the game", they assign problems THEY already know the answers to. In actual practice, it can be VERY DIFFICULT to decide if a sequence converges. It's an art-form, really, there are a few "tricks" to use, but sometimes everything you try doesn't help.
so it can be $\infty$ at times and still be convergent?
You'll have to be more specific, I'm afraid, as I have no idea what you mean by this.
Try to avoid speaking of infinity as if it was a number-it's not. It is sometimes used as a handy abbreviation for more wordy ways of saying things.
For example, when we say a sequence "goes to infinity", we don't mean that:
There exists $k$ such that: $a_k = \infty$.
We mean instead: for every natural number $N$, there IS a $k$ such that for all $n > k$, we have $a_n > N$.
Note the last statement doesn't even mention infinity, it just means that there is no $N$ that "bounds" the sequence $\{a_n\}$.
For example, if:
$a_n = \dfrac{1}{n - 3}$
then $a_3$ is undefined, it's not "infinity".
if i am given a sequence and i take the limit and it goes to infinity, does that mean it diverges. Likewise, if I take the limit of a sequence and i get a real number (finite number) such as 0 or 1, that means it converges. right?
If the $n$th term increases/decreases without bound, then you know it diverges, but in order for the series to converge the $n$ term must approach zero as $n\to\infty$, and while this is a necessary condition, it is not a sufficient condition...it must approach zero quickly enough for the series to converge. Consider the harmonic series:
\(\displaystyle S=\sum_{k=1}^{\infty}\frac{1}{k}\)
The $k$th term does indeed approach zero as $k$ increases without bound, but the series itself diverges.
Except this thread is about convergence of SEQUENCES, not series :P
yeah I am talking about if I am given like $a_n$ or something and then i asked if it converges or diverges.
Then just take the limit...if it is a real number, it converges. :D
excellent answer Mark. very clear answer to my question :)
appreciate all the other answers too :)
FAQ: How do i determine if a sequence converges or diverges
What is the definition of convergence and divergence in a sequence?
The convergence of a sequence means that the terms in the sequence approach a specific value as the number of terms increases. In contrast, a sequence diverges if the terms do not approach a specific value and instead become infinitely large or oscillate between different values.
How can I determine if a sequence converges or diverges without calculating an infinite number of terms?
There are several tests that can be used to determine the convergence or divergence of a sequence, such as the ratio test, the root test, and the comparison test. These tests involve analyzing the behavior of the terms in the sequence to determine if they approach a specific value or become infinitely large.
Can a sequence converge to more than one value?
No, a sequence can only converge to one specific value. If a sequence has multiple subsequences that converge to different values, then the sequence itself is said to diverge.
What is the significance of determining if a sequence converges or diverges?
Determining the convergence or divergence of a sequence is important in many mathematical applications, such as in calculating limits, series, and integrals. It also has practical applications in fields such as physics, engineering, and economics.
Are there any general rules for determining the convergence or divergence of a sequence?
While there are specific tests that can be used to analyze the behavior of a sequence, there are no general rules that apply to all sequences. Each sequence must be analyzed individually to determine its convergence or divergence. Additionally, some sequences may not converge or diverge using the known tests, and further analysis may be required to determine their behavior.
