MHB How do I determine the coordinates of points on a 3-D coordinate plane?
Determining coordinates on a 3-D coordinate plane involves understanding the relationship between the x, y, and z axes. It is impossible to recover a point's coordinates from a 2-D picture due to the infinite possibilities of 3D points projecting to the same location. A practical method for finding coordinates is to visualize the point's position starting from the origin, moving along each axis according to the given values. Problems with connecting lines to the axes simplify the process, allowing for easier identification of coordinates by following straight paths. Accurate interpretation of the coordinates is essential for solving related problems effectively.
ssmith9bmr
View attachment 2428View attachment 2428
Can someone please help me with this? I can't for the life of me figure out how to do these points. How do I line up the x, y, and z? I just can't grasp it and can't find anything online.
Mathematics news on Phys.org
Concerning problem 1), it is impossible to recover coordinates of the shown point from a two-dimensional picture. That is, there is an infinite number of 3D points that, when drawn on a plane, would fall into the same position. However, we are also given four options, and of those only one corresponds to the required point.
The most reliable way to find the answer is to draw all four points. To draw a point with coordinates $(x_0,y_0,z_0)$ start with the origin, then move in the direction of the $x$ axis by $x_0$ (in the picture, this means moving bottom left for positive $x_0$), then move in the direction of the $y$ axis by $y_0$ (right for positive $y_0$) and finally in the direction of the $z$ axis by $z_0$ (up for positive $z_0$). But one can also see that the required point has a negative $z$ coordinate, and there is only one corresponding option.
Problem 2)
Problems 3) and 4) are easier because we have lines connecting the point with the coordinate axes. For 3), we first go up to the $xy$ plane and then left to the $x$ axis. We arrive at $x=4$. Similarly, going up and then towards the $y$ axis we arrive at $y=4$. Finally, going towards the $xy$ plane (where $z=0$) required going up 1 unit, so the $z$ coordinate is $-1$. Note that each time we move along a straight line segment, it must be parallel to one of the axes. The answer to 4) is $(-1,2,-4)$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
