MHB How do I determine the type of discontinuity for a discontinuous function?
To determine the type of discontinuity for a function, one can classify it as removable, jump, or essential based on the behavior of the function around the discontinuity point. For the function (x^2 - 36)/(x+6), it is continuous at x=6 but discontinuous at x=-6 due to the denominator being zero. Factoring the function can help identify removable discontinuities if terms cancel out; otherwise, it may indicate an essential discontinuity. Understanding left-sided and right-sided limits is crucial for accurate classification. In this case, the discontinuity at x=-6 is removable since the function can be simplified.
LostMathStudent
I need help with discontinuous functions. More specifically, how to determine what type of discontinuity they are, algebraically.
Example: Determine whether each function is continuous at the given x values. Justify using the continuity test. If discontinuous, identify the type of discontinuity
(x^2 - 36)/(x+6); at x=-6 and x=6
Alright, so I know the function is continuous at 6, but discontinuous at 6 because the value makes the denominator a zero.
Now, how do I determine what type of discontinuity this function is? Is there a certain way I should preferably be doing this? I'm honestly pretty lost.
Mathematics news on Phys.org
Note that
$$\frac{x^2 - 36}{x+6} = x-6$$
What can you say about the discontinuities of this function then?
Hi LostMathStudent! Welcome to MHB! :)
We usually distinguish 3 types of discontinuities: removable, jump, and essential.
You can find the classification of discontinuities on wikipedia.
It's possible though that in your textbook the names are slightly different.
In short, it's removable if the function is smooth, but there is just a point missing.
It's a jump if the function makes a jump at the point in question.
And otherwise it is called (by some sources) an essential discontinuity.
What type do you think you have?
I know the differences between all the discontinuities, except in our class we call essential discontinuity infinite discontinuity.
Could I factor the function, and then if they cancel out I know I have removable discontinuity? Then, if they don't cancel, I still have essential discontinuity.
I'm not sure if this works on all functions, including square root functions and piecewise functions. I'm assuming that square root functions can only have removable discontinuity, and piecewise can only have jump discontinuity.
That sounds pretty good.
Formally these classifications are done based on left-sided and right-sided limits.
Are you familiar with those?
Otherwise your classifications seem to hit the mark.
However, suppose you have the piecewise function:
$$f(x)=\begin{cases}
x &\text{if }x \ne 0 \\
1 &\text{if }x = 0 \end{cases}$$
Then the discontinuity at $x=0$ is removable instead of a jump discontinuity.Anyway, in your current problem you can indeed factor and cancel the denominator, making it a removable discontinuity.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
