Torque is a measure of the force that causes an object to rotate around an axis. It is directly related to acceleration because the greater the torque applied to an object, the greater the acceleration it will experience.
To calculate the torque required for acceleration, you will need to know the mass of the object, the distance from the axis of rotation to the point where the force is being applied, and the angular acceleration. Then, use the formula torque = mass x distance x angular acceleration.
No, in order to calculate torque for acceleration, you will need to know the angular acceleration. This is because torque is directly proportional to angular acceleration, so without knowing one, you cannot accurately determine the other.
The distribution of mass does affect the torque required for acceleration. Objects with a greater distance between the axis of rotation and the center of mass will require less torque for the same amount of acceleration compared to objects with a smaller distance between the two.
Yes, there is a maximum torque that can be applied for acceleration. This is determined by the physical limitations of the object, such as its mass and strength. Applying torque beyond this limit can cause the object to break or fail to accelerate.
