NewtonianAlch
- 453
Are the following statements true or false? Explain your answers carefully, giving all necessary working.
(1) p[itex]_{1}[/itex](t) = 3 + t[itex]^{2}[/itex] and p[itex]_{2}[/itex](t) = -1 +5t +7t[itex]^{2}[/itex] form a basis for [itex]P_{2}[/itex]
(2) p[itex]_{1}[/itex](t) = 1 + 2t + t[itex]^{2}[/itex], p[itex]_{2}[/itex](t) = -1 + t[itex]^{2}[/itex] and p[itex]_{3}[/itex](t) = 7 + 5t -6t[itex]^{2}[/itex] form a basis for [itex]P_{2}[/itex]
So I rendered both (1) and (2) into matrices and did row reduction on them:
[PLAIN]http://img411.imageshack.us/img411/9639/43512286.jpg
I believe (1) does not form a basis for [itex]P_{2}[/itex] because there is no solution even though the vectors are linearly independent. Where as (2) does have a solution and the vectors are linearly independent so therefore it should form a basis.
Thoughts: To form a basis in [itex]P_{2}[/itex] wouldn't you need at least 3 vectors always? In my book it states that to form a basis the vectors need to be linearly independent (which is established) and also must be a spanning set, what does this exactly mean?
It also does an example of 3 vectors just like (2): here's what the end result of their row-reduction looked like:
[PLAIN]http://img443.imageshack.us/img443/489/17419228.jpg
Their comment was
The row-echelon matrix had a non-leading right-hand column and hence the equation Ax=b has a solution. Therefore span(S) = R[itex]^{3}[/itex].
Moreover, the left side of the row-echelon matrix has no non-leading columns, so the only solution for a zero right-hand side is x[itex]_{1}[/itex] = x[itex]_{2}[/itex] = x[itex]_{3}[/itex] = 0. This shows that S is a linearly indepedent set. We have now proved S is a linearly independent spanning set for R[itex]^{3}[/itex] and is therefore a basis for R[itex]^{3}[/itex]
So does this mean if b3 - 2b2 + b1 = 0, then it wouldn't be a spanning set and hence not a basis? Why is this?
