How do I do this simple looking integral?
  • Thread starter frasifrasi
  • Tags
    Integral
In summary, to evaluate the given integral, we first write it in the form of two integrals: one for 1 and one for 1/(x+1). Then, we can find the antiderivative for 1/(x+1) by using the substitution u=x+1. However, since ln(0) is undefined, the integral diverges. We can also make the substitution u=x+1 in the limits of integration to simplify the integration process. Overall, the integral diverges due to the undefined value of ln(0).
frasifrasi
276
Ok, we are supposed to evaluate
int from -1 to 0 of x/(x+1) dx
---> my first step was to write (x+1) -1/(x+1) to form the two integrals: of 1 and 1/(x+1)
--> is this the right way? The answer is "it diverges."
You are on the right path; what is the antiderivative of 1/(x+1)?
If I get the antiderivatives:
x] - [ln(u)] ? -- Am i supposed to substitute u for (x+1) before proceeding?
you don't have to, this problem you can pretty much eyeball.
but if you had like 2x+1 in the denominator, then you would need worry about constants.
So, the lim n -->-1 of ln(n) is infinity?
If we let u=x+1 then du=dx
So then x=u-1 and dx=du
It's a way similar to what you did, and since ln(0) is undef. it diverges.
so, I do have to sub x+1 back I guess...
Either that or change the limits of integration as you go. If you make the substitution u= x+1 and your limits of integration, with respect to x, were x= -1 and x= 0, then the limits of integration become u= -1+1= 0 and u= 0+ 1= 1.
but then the integral wouldn't diverge, would it?
ln(u), where u=0 will definitely diverge
FAQ: How do I do this simple looking integral?
How do I solve an integral using the power rule?
To solve an integral using the power rule, first identify the exponent of the variable in the integrand. Then, add 1 to the exponent and divide the coefficient by the new exponent. Finally, add "x" to the new exponent and include a constant of integration.
What is the difference between a definite and indefinite integral?
A definite integral has limits of integration, meaning it will result in a specific numerical value. On the other hand, an indefinite integral does not have limits of integration and will result in a general equation that can be solved for any value of the variable.
How do I use substitution to solve an integral?
To use substitution, first identify a part of the integrand that can be replaced with a single variable. Then, substitute that variable into the integrand and change the limits of integration accordingly. Finally, solve the resulting integral using basic integration techniques.
Can I use a calculator to solve integrals?
Yes, there are many online and handheld calculators that can solve integrals. However, it is important to understand the concepts and techniques behind integration in order to use these tools effectively.
What is the purpose of integration in science?
Integration is used to find the area under a curve and to solve problems involving rates of change, such as velocity and acceleration. It is an essential tool in many scientific fields, including physics, engineering, and economics.
