How do I do this with KCL and KVL
  • Thread starter strk
  • Tags
    Kcl Kvl
In summary, mesh analysis is used to find the voltages at the nodes of a mesh. Node analysis is used to find the voltages at the nodes of a mesh.
strk
http://i139.photobucket.com/albums/q292/strkthug/KCL/kclandkvl.png
I think since x2 is 2a and x3 is 3a then x5 should be 5a
and I have no idead where to go from there
First, do a mesh analysis. Then, do a node analysis. Just do it one step at a time and you'll get it.
what is mesh analysis and node analysis? how do I even start that out
I assume that you've been taught what KCL and KVL are.
Therefore, you know that in each of the three loops (or, meshes), the sum of the voltages (i * r) or x, in this case equals zero. That give you three equations. Start there and see what you get.
Watch the signs!
Since the problem asks you to use KCL and KVL, we will assume that you know what they are. strk was just using alternate common names for them:
KCL = node (nodal) analysis
KVL = mesh analysis
Please show us your work, if you'd like us to check your answers.
i tried to solve it by KVL using signs of currents and got these:
Vx3=-1
Ix5=-5
Vx2=-4
Ix4=-3
but i don't know wether its right or not
I don't have time to check right now. However, you should be able to verify your answers using KCL and/or Ohm's law. That is the normal method to show yourself that the value you have found is correct...
Vx3=-1
Ix5=-5
Vx2=-4
Ix4=-3
Okay, my answers are a little different.
For all of the currents that you don't know, you can do KCL --
So, we need to find Ix4 and Ix5.
For, Ix4, let's look at the node where x4,2, and 1 meet.
There you have...
1A + 2A = Ix4 --> Ix4 = 3A
for, Ix5, let's look at the node where x2, 3, and 5 meet.
There you have...
3A + 2A + Ix5 = 0 --> Ix5 = -5A
Now, you have three more voltages to find; Vx2, 3, and 1.
For the loop with x4, 2, and 5, you have...
-1V - 3V + Vx2 = 0 --> Vx2 = 4V
For the loop with x5 and x3, you have...
-Vx3 + 1 = 0 --> Vx3 = 1V
For the loop with x2, 3, and 1, you have...
Vx1 + 1V - 4V = 0 --> Vx1 = 3V
I hope that helps... Watch your signs! Start with what you KNOW and take small steps to find the solution!
There you have...
There you have...
that's right you got same answers by using its directions
Right, Hosam. However, you have to know that 4V does not equal -4V! Very tricky. Very tricky, indeed.
Related to How do I do this with KCL and KVL
1. How do I apply KCL to a circuit?
To apply KCL (Kirchhoff's Current Law) to a circuit, you must first identify all the nodes in the circuit. Then, write down an equation for each node, where the sum of all currents entering the node is equal to the sum of all currents leaving the node. Finally, solve the equations simultaneously to find the unknown currents.
2. How do I use KVL to solve a circuit?
To use KVL (Kirchhoff's Voltage Law) to solve a circuit, you need to identify all the loops in the circuit. Then, write down an equation for each loop, where the sum of all voltage drops in the loop is equal to the sum of all voltage sources in the loop. Finally, solve the equations simultaneously to find the unknown voltages.
3. Can I use KCL and KVL together in a circuit?
Yes, KCL and KVL can be used together to solve a circuit. KCL is used to analyze the current flow at each node, while KVL is used to analyze the voltage drops and sources in each loop. By using both laws together, you can find all the unknown currents and voltages in the circuit.
4. What is the difference between KCL and KVL?
KCL and KVL are two different laws that are used to analyze electrical circuits. KCL is used to analyze the current flow at each node in the circuit, while KVL is used to analyze the voltage drops and sources in each loop. Essentially, KCL deals with currents and KVL deals with voltages.
5. Are there any limitations to using KCL and KVL?
While KCL and KVL are powerful tools for analyzing circuits, there are some limitations to their use. These laws assume that the circuit is made up of ideal components, and do not take into account any non-idealities such as resistance, capacitance, or inductance. Additionally, KCL and KVL can only be applied to linear circuits, where the current-voltage relationship is linear.
  • Electrical Engineering
