How do I evaluate the integral for a specified area on the xy-plane?
  • MHB
  • Thread starter Petrus
  • Tags
    Integral
In summary, the conversation discusses solving an integral over a rectangle and the use of nested integrals. It also mentions the definition of volume and provides an exercise to evaluate the volume of a cube. The resulting volume is compared to the formula for the volume of a cube to show the accuracy of the method.
Petrus
702
Hello MHB,
This is an exemple I do not understand.
if \(\displaystyle R={(x,y)|-1 \leq x \leq 1, -2 \leq y \leq 2}\), evaluate the integral
\(\displaystyle \int\int_R \sqrt{1-x^2}dA\) (It is suposed to be R at down for 'rectangle' if I understand correct.)
they solve it like this \(\displaystyle \int\int_R \sqrt{1-x^2}dA = \frac{1}{2} \pi(1)^2 * 4 = 2\pi\)
I don't understand how they do it and
The defination says:
"If \(\displaystyle f(x,y) \geq0\), then the volume V of the solid that lies above the rectangle R and below the surface \(\displaystyle z=f(x,y)\) is
\(\displaystyle V=\int\int_R f(x,y)dA\)"
What I can note is that \(\displaystyle \sqrt {1-x^2} \geq0\) and \(\displaystyle z=\sqrt{1-x^2} <=> x^2+z^2=1\) so then the volume lies above the rectangle and below \(\displaystyle z= \sqrt{1-x^2}\) but I get confused with dA, integrate respect to area?
Regards,
You are asked to solve the integral
\(\displaystyle \int^{2}_{-2} \, \int^{1}_{-1} \sqrt{1-x^2} \, dx \, dy\)
is it that easy >.<
Yes , you are asked to integrate over the rectangle [-1,1]x[-2,2]
How will it work with integrate with dy? I don't have any y in my function so..?
You can think of it as a nested integral so you start first by evaluating \(\displaystyle \int^1_{-1} \sqrt{1-x^2} \, dx \)
Then what ever the result you get assume to be f(y) then you evaluate
\(\displaystyle \int^{2}_{-2} f(y) \, dy \)
Thanks Zaid!:) One last quest why can I do that? I don't think I ever read about it or I have just missed it. Thanks!
This is what we call iterated integral .
- - - Updated - - -
Just as an exercise try to evaluate the integral of z=2 over the rectangle [0,2]x[0,2] and verify this is the volume of a cube.
- - - Updated - - -
This is what makes this forum so good:)! Thanks for helping me and giving me an exercise! I really like this thanks thanks!:)
we got :
\(\displaystyle \int_0^2\int_0^22 dxdy\) so the volume becomes \(\displaystyle V=8cm^3\) (I just like to have 'unit'
A cube is like 6 square View attachment 736 when our is 2cm long (Here is me draw it on paint but it looks like a rectangle but its a square) View attachment 737 formel for volume of a cube is \(\displaystyle a^3\) and our \(\displaystyle a=2\) ( lenght) so the volume of the cube becomes \(\displaystyle 2^3=8cm^3\)
Excellent , so we see that for positive z>0 this is actually the volume over the specified area on the xy-plane .
FAQ: How do I evaluate the integral for a specified area on the xy-plane?
What is an integral?
An integral is a mathematical concept used to find the area under a curve in a graph. It can also be thought of as a way to find the total value of a function over a specific interval.
What is the purpose of evaluating an integral?
The purpose of evaluating an integral is to find the exact value of the area under a curve or the total value of a function over a specific interval. This is useful in many real-world applications, such as calculating the work done by a force or finding the average value of a quantity.
What are the different types of integrals?
The two main types of integrals are definite and indefinite integrals. A definite integral has specific limits of integration and gives a numerical value, while an indefinite integral has no limits and gives a function as its result.
How do you evaluate a definite integral?
To evaluate a definite integral, you must first find the antiderivative (or the original function) of the integrand. Then, substitute the limits of integration into the antiderivative and subtract the lower limit from the upper limit to find the final numerical value.
What are some common techniques used to evaluate integrals?
Some common techniques used to evaluate integrals include substitution, integration by parts, partial fractions, and trigonometric substitutions. Each of these techniques has its own set of rules and guidelines, and the choice of which one to use depends on the complexity of the integral.
