I How do I express that a 100% occurrence in a small sample is low "confidence"?
In experiments A and B, both show a 100% frequency of an event, but the confidence in these results differs due to sample size. Experiment A, with only 2 trials, yields a 95% confidence interval of (1, 1), indicating low confidence in the result. In contrast, experiment B, with 100 trials, also has a 95% confidence interval of (1, 1), but the probability that the result is due to chance is significantly lower. Bayesian analysis using a beta distribution reveals that the credible intervals for both experiments differ, with experiment A showing a broader interval (0.368 to 1.000) compared to experiment B (0.971 to 1.000). This highlights the importance of sample size in determining the strength of experimental results.
Archosaur
TL;DR Summary
How do I express that a 100% frequency occurrence in a small sample is low "confidence", when, strictly speaking, its 95% confidence interval is (1,1)?
In experiment A: I observe an event 2 times in 2 trials.
In experiment B: I observe an event 100 times in 100 trials.
In both cases, I calculate a frequency of 100%
In both cases, I calculate a 95% confidence interval of (1, 1).
But intuitively the result of experiment B is "stronger" than that of A. How can I express this as a number?
Archosaur said:
TL;DR Summary: How do I express that a 100% frequency occurrence in a small sample is low "confidence", when, strictly speaking, its 95% confidence interval is (1,1)?
Assume a null hypothesis of whatever frequency you think is appropriate. 50% maybe. Then calculate the probability that such an experimental result is due to chance, ie. that your null hypothesis is true. This will usually be very close to zero in the second case.
Likes Agent Smith
Or you could do a Bayesian analysis and the 95% credible interval would not be (1,1) in either case, but it would be quite broad in the low data case and quite narrow in the high data case
In the Bayesian case a beta distribution is the conjugate prior for a binomial random variable. The posterior is ##\beta(a+1,b+1)## where ##a## is the number of successes observed and ##b## is the number of failures observed.
From that you can calculate the credible interval. For ##(a=2,b=0)## we find that the 95% credible interval for ##\beta(3,1)## is 0.368 to 1.000. In contrast, for ##(a=100,b=0)## we find that the 95% credible interval for ##\beta(101,1)## is 0.971 to 1.000
Likes Agent Smith
This is awesome. Thanks very much for pointing me to the Beta distribution - this is exactly what I was looking for. I made a python function that calculated frequency and "credibility" (1 - width of 95% credible interval) for O observations in N trials up to 100, because I was curious what a credibility heatmap would look like in this space.
Likes Agent Smith, berkeman and Dale
Excellent! Personally, I think that this behaves as a reasonable person would expect. With just 2 observations it seems reasonable to say “I am pretty sure the probability is greater than 30%”. And with 100 observations it also seems reasonable to say “I am pretty sure the probability is greater than 96%”.
Likes Agent Smith
Dale said:
In the Bayesian case a beta distribution is the conjugate prior for a binomial random variable. The posterior is β(a+1,b+1) where a is the number of successes observed and b is the number of failures observed.
This looks like Laplace's "formula" which he invented to answer the question "what is the likelihood that the sun will rise tomorrow?" If out of ##b## observations, the sun rose ##a## of those times, ##\text{P(sun will rise tomorrow)} = \frac{a + 1}{b + 1}##
