How do i factorize x^3 -5x^2+8x-4?
  • MHB
  • Thread starter theakdad
In summary, to factorize the expression x^3 - 5x^2 + 8x - 4, you first need to check for any common factors among the terms. In this case, there is a common factor of x, which can be factored out. Then, using the remaining terms, you can either use the grouping method or the factor theorem to find the remaining factors. After factoring, the final expression should be (x-1)(x-2)(x-2).
theakdad
211
\(\displaystyle x^3 -5x^2+8x-4\)
What is the simplest way to factorize given equation? Thank you.
Mathematics news on Phys.org
By sight You notice that x = 1 and a solution of the equation...
$\displaystyle P(x) = x^{3} - 5\ x^{2} + 8\ x - 4 = 0\ (1)$
... so that (x-1) divides P(x)... then divide P(x) by (x-1) and obtain a second order polynomial that possibly can be further factorized...
Kind regards
$\chi$ $\sigma$
Kind regards
$\chi$ $\sigma$
I do not understand the part "By sight"...
You could always try plotting it, it's not very rigorous mathematically but since polynomials are pretty well-behaved it's easy to spot roots most of the time.
+I have to find the roots of the polynomial...so have to factorize it...
Click Here
to see why plotting the polynomial is useful in finding the roots.
See there is one root at x=1
See there is a double root at x=2
Then the three roots can be used to factor P(x).
P(x) = (x - r1)(x - r2)(x - r3)
can you see why P(x) is zero at exactly the same x-values as (x - r1)(x - r2)(x - r3)?
What chisigma was getting at, is that if you observe that given:
\(\displaystyle P(x)=x^3-5x^2+8x-4\)
and you see that:
\(\displaystyle P(1)=1-5+8-4=0\)
then you know that:
\(\displaystyle P(x)=(x-1)f(x)\implies f(x)=\frac{P(x)}{x-1}\)
where $f$ is of degree 2. Thus we can use division to determine $f$:
\(\displaystyle \begin{array}{c|rr}& 1 & -5 & +8 & -4 \\ 1 & & +1 & -4 & 4 \\ \hline & 1 & -4 & 4 & 0 \end{array}\)
Thus, we have found:
\(\displaystyle P(x)=(x-1)\left(x^2-4x+4\right)\)
And so now you only have a quadratic left to factor...can you continue?
and you see that:
then you know that:
Yes,its obvious...
So i get \(\displaystyle (x-1) (x-2) (x-2)\)
i have three roots: X1 = 1 and X2,3 = 2
wishmaster said:
Yes,its obvious...
Yes, that's correct...you have the root $x=1$ and the root $x=2$, which is a repeated root, or of multiplicity 2.
I was just wondering how do you guess the first root...
In my example there is a simple polynomial...but what to do when you have harder cases?
Hi wishmaster,We just try all of $0,1,-1,2,-2$.
If none of those are roots we give up. :rolleyes:Alternatively, we can use the Rational root theorem. (Nerd)
It states that if all coefficients are integers and if there is a "guessible" root, it has to be of the form $\frac pq$, where $p$ is a divider of the last coefficient and $q$ is a divider of the first coefficient.
In your example $x^3 -5x^2+8x-4$, the symbol $p$ represents the dividers of $-4$, which are $\pm 1, \pm 2, \pm 4$.
And $q$ is a divider of $1$, which is one of $\pm 1$.
So if there is a guessible root, it is one of $\frac{\pm 1}{\pm 1}, \frac{\pm 2}{\pm 1}, \frac{\pm 4}{\pm 1}$.
That is, one of $-4,-2,-1,1,2,4$.
As you can see, all the actual roots (that is $1$ and $2$) are in there. (Mmm)
As a result of the remainder theorem,if x=b makes any polynomial vanish,then (x-b) is a factor of it.
Now,how could you find any number such b?
According to the rational root theorem,a possible integer root of such an equation should be a divisor of the constant term(here is 4) which are ;
1,2,4,and their negatives.
So,we should substitute them,one by one,starting from x=1 to see which one makes it vanish.
Here,x=1&2 make it vanish,then (x-1)(x-2) is a factor of it.
The other factor is f(x)/(x-1)(x-2),which is again (x-2).
So,f(x)=(x-1)(x-2)(x-2)=(x-1)(x-2)^2
Here are short tutorials on division;
https://www.youtube.com/watch?v=4ahKcCSL6Mg&list=PLsMjNmqC7C2T66EgsXhbS-zGiCQB3i2NU&index=17&t=0s
https://www.youtube.com/watch?v=Cti9roxbP4Q&list=PLsMjNmqC7C2T66EgsXhbS-zGiCQB3i2NU&index=29&t=0s
https://www.youtube.com/watch?v=bSh8G5FXay4&list=PLsMjNmqC7C2T66EgsXhbS-zGiCQB3i2NU&index=30&t=0s
https://www.youtube.com/watch?v=EagRlnlgmtg&list=PLsMjNmqC7C2T66EgsXhbS-zGiCQB3i2NU&index=31&t=0s
Substituting can be annoying.I mean,how would you evaluate the polynomial for x=4?!
Let’s calculate it by a fast substituting method;
x^3=x^2.x
Now plugging 4 into x,
x^3=x^2.x=x^2.4=4x^2
So,f(x)=x^3-5x^2+8x-4=4x^2-5x^2+8x-4=-x^2+8x-4
Again,writing -x^2=-x.x,and setting x=4,
x^2=-x.x=-x.4=-4x
So,f(x)=-x^2+8x-4=-4x+8x-4=4x-4
Setting x=4,f(x)=4(4)-4=12
You could well learn this method by watching the short tutorials below;
https://www.youtube.com/watch?index=19&list=PLsMjNmqC7C2T66EgsXhbS-zGiCQB3i2NU&t=0s&v=Kq5AKAXOOSc
https://www.youtube.com/watch?index=20&list=PLsMjNmqC7C2T66EgsXhbS-zGiCQB3i2NU&t=0s&v=r2EXS-mjPC0
https://www.youtube.com/watch?index=26&list=PLsMjNmqC7C2T66EgsXhbS-zGiCQB3i2NU&t=0s&v=2BoGYi0p5N4
Just because the Rational Roots Theorem is not entirely obvious, some reasoning behind it...
We would be expecting that your degree "n" polynomial would factorise to a form like
$\displaystyle \begin{align*} P\left( x \right) = \left( a\,x + b \right) \left( c\,x + d \right) \left( e\,x + f \right) \dots \left( w\,x + z \right) \end{align*}$
so that the roots are $\displaystyle \begin{align*} x = \left\{ -\frac{b}{a} , -\frac{d}{c} , -\frac{f}{e} , \dots , -\frac{z}{w} \right\} \end{align*}$
The polynomial expands out to
$\displaystyle \begin{align*} P\left( x \right) = ace\dots w\,x^n + \left( \textrm{middle terms} \right) + bdf\dots z \end{align*}$
and now it can clearly be seen that the NUMERATOR of each of the possible roots must be a factor of the constant term, while the DENOMINATOR must be a factor of the leading coefficient.
Now, I know that in cases where those particular numbers have a lot of factors, it would mean that there would be a large number of possible roots to test. But the beauty is that you do end up with a FINITE number of possibilities, which is ALWAYS better than an infinite number.
FAQ: How do i factorize x^3 -5x^2+8x-4?
What is factorization?
Factorization is the process of finding the factors of a polynomial, which are the expressions that can be multiplied together to obtain the original polynomial.
What are the steps involved in factorizing x^3 -5x^2+8x-4?
The steps for factorizing x^3 -5x^2+8x-4 are as follows:1. Look for a common factor, if any, among the terms. In this case, the common factor is x.2. Group the terms with the common factor together. This gives us x(x^2 -5x +8) -4.3. Factor the remaining polynomial inside the parentheses. In this case, we can use the quadratic formula or trial and error to find that the factors are (x-4)(x-1).4. Rewrite the original polynomial using the factors. This gives us x(x-4)(x-1) -4.5. Simplify the expression if possible. In this case, there are no further simplifications, so the final factorization is x(x-4)(x-1) -4.
Are there any special cases to consider when factorizing a polynomial?
Yes, there are a few special cases that can make factorization more challenging. These include:- The polynomial may have a common monomial factor, such as x or 2x.- The polynomial may have a common binomial factor, such as x+2.- The polynomial may have a perfect square trinomial as a factor, such as x^2 + 6x +9.
What is the purpose of factorizing a polynomial?
Factorization is useful in many areas of mathematics, including algebra, calculus, and number theory. It allows us to simplify expressions, solve equations, and find the roots of a polynomial. It also helps us understand the relationships between the terms in a polynomial and can help us identify patterns and make predictions.
Can all polynomials be factorized?
No, not all polynomials can be factorized. Some polynomials have complex roots, which means they cannot be written as a product of simpler expressions. Other polynomials may have irrational or imaginary roots, which also cannot be factored using real numbers. However, all polynomials can be factored using complex numbers.
