How do i figure out area under the the red-brown line graph?
In summary: I think you are correct. I am so used to seeing people use the trapezoidal rule to approximate a curve which they do not know the equation of, that it didn't occur to me that the OP was using it on data that were measured from the curve.
Kaleem
The figure below represents part of the performance data of a car owned by a proud physics student. (The horizontal axis is marked in increments of 2 seconds and the vertical axis is marked in increments of 10 m/s.)
(a) Calculate the total distance traveled by computing the area under the red-brown graph line. In kilometers.
a = (ΔVx)/Δt
Speed = Total distance/Total Time
I tried to use the trapezoidal method and break it up into 5 increments as I haven't learned how to integrate yet.
Trapezoidal Method
1/2*(f(0) + 2*f(1) + 2*f(2) + 2*f(3) + 2*f(4) + f(5) )
1/2*(f(0) + 2*f(33) + 2*f(50) + 2*f(50) + 2*f(48) + f(0)) = 181 x 10-3 = .181 km
However the answer was a little bigger than what I got which was .375 kilometers.
a = (ΔVx)/Δt
Trapezoidal Method
1/2*(f(0) + 2*f(33) + 2*f(50) + 2*f(50) + 2*f(48) + f(0)) = 181 x 10-3 = .181 km[/B]
The region of the graph whose area you're trying to determine is itself approximately a trapezoid.
Find its area.
Find its area.
Would I just need to use the formula (a + AB + BC)/2 * h then? If so what would be a good way to figure out the height?
a = (ΔVx)/Δt
Trapezoidal Method
The notation you are using is confusing.
You are given that the horizontal coordinate is time in increments of 2 sec.
If you want to write the ordinates of the curve using functional notation, you would use, for example, f(2) = 33 m/s, not f(33), which suggests you want to find the velocity when t = 33 sec.
As to your application of the trapezoidal rule, you got that mostly correct, except you overlooked that the spacing between your ordinates was 2 sec., not 1 sec.
The trapezoidal formula is A = (1/2) * h * [y1 + 2 * y2 + ... + 2 * yn-1 + yn]
In this instance, h = 2 sec.
Er, read it off the graph.
You have got there a rectangle and two triangles. The triangles are not the same area as each other though.
I think I've got it down now, I have broke it down to (1/2)*2*(0+2(33)+2(50)+2(50)+2(48)+0) which gives me 362 meters, and converted to kilometers it would give me .362 km.
You've divided it into five areas, you only needed to divide it into three, see #5, and more seriously you've calculated the triangle areas wrong.
How exactly did I mess up the areas?
Just look at the first triangle. It's area is not ½ × 2(32) as you have written. The last one is not right either.
Then if you divided into fewer areas as I suggested you would make fewer errors - even if the percentage is the same :oldtongue:
I believe the OP is using the trapezoidal rule to calculate the area under this curve:
In applying this rule, the ordinates of the curve at evenly spaced intervals are used, rather than calculating triangles and whatnot.
I suspect that OP recognized something which looks rather like a trapezoid, then tried to use something called the trapezoid rule.
Yes, I've been trying to use the trapezoid rule
Any particular reason for using that rule?
It was one of the only ways that I knew how to find the area under the line, since I haven't learned how to integrate yet.
Forget the trapezoid rule, unless you were explicitly instructed to use it.
Except for the rounded corners, you do have a trapezoid, the vertices of which are at
(0, 0), (3, 50), (8. 50), and (10, 0) ,
The x coordinates being in units of seconds, and the y coordinates in units of m/s.
The trapezoidal rule, while not as elegant as some methods of numerical integration, is a valid technique for calculating the area under this curve:
http://www.math.vt.edu/courses/math2015/Labs/Lab2/TTrap1.html
The trapezoidal rule is first cousin to Simpson's Rule and other rules for integration.
The OP calculated an area of 0.362 km using the trapezoidal rule, and the correct answer, also according to the OP was 0.375 km.
Approximately right answer looks like cancellation of errors to me. Most people who have left school won't remember what a trapezoid even is let alone its rule. I had to look the first up, not bothered with the second.
There you've got a triangle base 3 height 50 area = 3 X 50/2 = 75
A rectangle 5 X 50 Area = 250
A triangle base 2 height 50 area = 2 X 50/2 = 50
+. +. +. = 375
Simples. "Be a country boy".
+. +. +. = 375
Now I see what you did, this method seems a lot simpler than what I was originally thinking.
When I calculate the ΔV/Δt it will give me acceleration which I can then use to find the distance, I think I've got the hang of this now.
Perhaps, but the curve as shown is not really a true trapezoid either, what with those rounded corners.
It's OK to admit that the OP caught you flat-footed by using the trapezoidal rule to figure the area under this curve. :sorry:
That's too bad, because both rules are rather easy to remember, and each gets used in quite a few situations.
In my line of work, knowing how to use the various rules for numerical integration is second nature, and that includes knowing not only the trapezoidal rule, but also the first and second Simpson's rules and the various Gauss quadrature techniques, as well. :wink:
Likes SammyS
Reading the OP's first attempts I thought we'd be doing well to help him towards an 8/10 and not be over-ambitious. :oldbiggrin: Best is enemy of good!
Turns out who set the question thought same way. :oldlaugh:
SteamKing said:
It's OK to admit that the OP caught you flat-footed by using the trapezoidal rule to figure the area under this curve. :sorry:That's too bad, because both rules are rather easy to remember, and each gets used in quite a few situations.
Well useful as you say in your line of work, on the other hand most people won't be there. :oldsmile:
Useful to more people to have seen them once or twice.
I don't mind not knowing the trapezoid rule, I managed without it. All bings back to me a friend at school who advanced the theory that it was bad to know things, because it made the mind rigid. :oldlaugh: I sort of still see what he meant. And one could fetch quotations from Einstein and Francis Crick to that effect. But mustn't go further down that line... except to say aren't we dealing here with a lot of students who 'know' things but are blocked in doing anything with them?
The OP seemed to be applying some rules but they were more hindrance than help to him IMHO.
On areas I remember a colleague with a lot of measurements of the sorts of things, radioactive incorporations etc. you measure over a cell cycle in culture who needed the areas. He couldn't remember the formulae. He just cut out silhouettes of the graph paper plots and weighed them. Good a method as any for his and many other purposes.
Weighing a scaled plot is (or was I should say) an accepted analog method of finding an area, assuming you had a known area to weigh and compare. By suspending the same shape from several different points and dropping a vertical line using a plumb bob, the intersection of these lines would also indicate the center of gravity of the shape.
In addition to numerical methods of integration, a variety of instruments were invented in the 19th century to perform such tasks. At one time, every engineer was introduced to using a simple planimeter to calculate area, and more complex (and expensive) instruments called integrators were crafted to perform first and second moment of area calculations for planar regions. All of these instruments operated using what was later known as Green's theorem in the plane to make their calculations.
Likes epenguin
Related to How do i figure out area under the the red-brown line graph?
1. How do I calculate the area under the red-brown line graph?
To calculate the area under the red-brown line graph, you can use the trapezoidal rule or the average value method. The trapezoidal rule involves dividing the graph into trapezoids and calculating the area of each trapezoid, then adding them together. The average value method involves finding the average value of the graph and multiplying it by the width of the graph.
2. What is the significance of finding the area under a line graph?
Finding the area under a line graph can provide valuable information about the data represented by the graph. It can help determine the total amount or value represented by the graph, as well as the rate of change over time.
3. How can I use software to calculate the area under a red-brown line graph?
There are many software programs available that can help you calculate the area under a red-brown line graph. Some popular options include Microsoft Excel, MATLAB, and Python. These programs have built-in functions or libraries that can perform the necessary calculations.
4. Can I estimate the area under a red-brown line graph?
Yes, it is possible to estimate the area under a red-brown line graph by using a method called numerical integration. This involves dividing the graph into smaller sections and using basic geometric shapes (such as rectangles or trapezoids) to approximate the area. While this method may not be as accurate as using the trapezoidal rule or average value method, it can still provide a close estimate.
5. Are there any limitations to calculating the area under a red-brown line graph?
Yes, there are some limitations to calculating the area under a red-brown line graph. One limitation is that it assumes the data represented by the graph is continuous and does not have any gaps or missing values. Additionally, the calculations may be affected by any outliers or extreme values in the data. It is important to carefully consider these factors when interpreting the results of the area calculation.
17K
11K
