How do I find distance given time and an arbitrary distance?
  • Thread starter Eclair_de_XII
  • Tags
    Time
In summary: Your previous work did not even involve the time variable, so you might as well just throw out that work.I'm confused as to why the equation for the time the ball spends going up and the time the ball spends going down are being added?They are not being added. You are writing two separate equations, one for the upward trip and one for the downward trip. Once you have written these equations, you can set them equal to each other and solve for the unknown distance from the window to the top of the building.I'm confused as to why the equation for the time the ball spends going up and the time the ball spends going down are being added?You are not adding the times
  • #36
Eclair_de_XII said:
This is the progress I've made so far. I'm having trouble finding the distance from the bottom of the window to the bottom of the building.
##x_1-x_0=\frac{1}{2}(9.8\frac{m}{s^2})(1.042092s)^2##
##x_1-x_0=5.3212m##
##5.3212m=v(1.042092s)-\frac{1}{2}(9.8\frac{m}{s^2})(1.042092s)^2##
##v=10.2125\frac{m}{s}##
##v_0=10.2125\frac{m}{s}##
##x_1=5.3212m+x_0##
##x_3=0m##
##t_3=2s##
Since the time it took for the ball to pass the window going down is equal to the time for the ball to pass it going up, I will assume that the window's in the middle of the building.
##-5.3212m-x_0=(10.2125\frac{m}{s})(1s)+(4.9\frac{m}{s^2})(1s)^2##
##-x_0=(15.1125m+5.3212m)##
##x_0=-20.43m##
I'm not sure what to make of the negative sign...
I think you're trying too hard to use a negative sign in your calculations when you don't need one.
If we take x0 as the top of the building, we can arbitrarily set x0 = 0 m and make that our reference point. We can also say that we drop the ball at t = 0 sec. and use that as a reference point for our timing of the fall of the ball.
For each second after the ball is dropped, the ball travels so many meters, which distance we add to our reference point for distance, x0 = 0 m.
For example, when t = 1.042 sec., the ball has dropped 5.321 m approx., which is where it passes the bottom of the window on its way to the ground. We are told the ball spends a total of 2.0 seconds below the bottom of the window while it falls to the ground, hits, and then bounces back up to the bottom of the window. From this description, we can infer that the total time it took the ball to fall from the roof to the ground is 1.042 + 1.0 = 2.042 sec. Since the initial velocity of the ball was 0 m/s, it becomes very easy to calculate the height of the building using the total time of free fall.
In these situations, making a simple sketch helps to clarify things.
  • #37
##x=x_0+v_0t+\frac{1}{2}at^2##
##x=\frac{1}{2}(9.8\frac{m}{s^2})(2.042s)^2##
##x=20.43m##
