How do I find final velocity using conservation of energy
In summary: The book answer says 190 m/s.Remember that energy is a scalar quantity, so we want to use the magnitude of the velocity as our ## v_i ## and our ## v_f## instead of ##(v_x)_i##, ##(v_y)_i## ##(v_x)_f## and ##(v_y)_f##. Also, this equation may help you solve this problem: ## \Delta{E} = E_f - E_i = 0J ## What are ## E_f ## and ## E_i ##?It also helps to solve your problem in terms of variables
Alameen Damer
76
A paintball gun launches a paintball off a cliff at an angle of elevation of 45°. The cliff is 165 m high. The paintball is initially moving at 180 m/s. Calculate the speed of the paintball as it hits the ground. I'm having trouble understanding how to solve this, I have posted my attempt.
Ek=1/2mv^2
Eg=mgh
I'm going to find the kinetic energy using the initial velocity.
So, cos 45 x 180 = 127.3 m/s. <---- This is velocity in the x direction
Ek=1/2 m *(127.3)^2
=8102.6m
Find height by subbing this into the Eg formula:
8102.6m=mgh
8102.6=9.8h
826.8=h
So this is the height of the projectile, in reference to the cliff. The total height however should have the 165m of the cliff added: Therefore it is (826.8+165)=991.8 m
This is the maximum height, I will use it to find the total energy at max height, so
Eg=991.8gm
=991.8(9.8)m
=9719m
Now I sub this into Ek to find the Velocity.
Ek=9719m
1/2mv^2=9719m
1/2v^2=9719
v^2=19439
v=139 m/s
Using the x component of velocity to find a height? (It doesn't make a difference mathematically since the angle is 45 degrees, however typically we the x-axis is horizontal) I would have written this off as a typo but you used cosine as well.
Eg=991.8gm
=991.8(9.8)m
=9719m
The total energy of the system should not change, correct? Check what the total energy was at t=0 and compare it with this.
I used cosine because I was trying to find height at the maximum point, where no forces act along the x direction. How can i find total energy at t=0, do i consider it as potential, (before launch)?
CosӨ gives the relationship between the x component of the velocity and the original velocity.
EDIT: I should specify that this is only the case when the angle is between the horizontal and the hypotenuse, which is the case in this question.
Heights correspond to the y-axis unless you've switched them for some reason. But since you didn't explicitly state it I assume your going with the convention that X is horizontal and Y is vertical.
Alameen Damer said:
How can i find total energy at t, do i consider it as potential, (before launch)?
Add kinetic and potential energy using the initial conditions.
Ek=1/2mv^2
Eg=mgh
Ek=1/2 m *(127.3)^2
=8102.6m
8102.6m=mgh
8102.6=9.8h
826.8=h
Eg=991.8gm
=991.8(9.8)m
=9719m
Ek=9719m
1/2mv^2=9719m
1/2v^2=9719
v^2=19439
v=139 m/s
It also helps to solve your problem in terms of variables, check the units to see if they match up with velocity's units, and only then plug in given values! If you become competent at solving problems generally, it will trivialize solving problems individually. You may also recognize the equation you find when solving generally... :)
Likes Phynos
FAQ: How do I find final velocity using conservation of energy
What is the concept of conservation of energy?
The law of conservation of energy states that energy cannot be created or destroyed, but can only be transferred or converted from one form to another. In the context of finding final velocity, this means that the total energy of a system remains constant throughout the motion, and can be used to calculate the final velocity of an object.
What is the equation for calculating final velocity using conservation of energy?
The equation for calculating final velocity using conservation of energy is: Vf = √(Vi² + 2gh), where Vf is the final velocity, Vi is the initial velocity, g is the acceleration due to gravity, and h is the change in height of the object.
What are the necessary parameters to calculate final velocity using conservation of energy?
The necessary parameters to calculate final velocity using conservation of energy are the initial velocity, the acceleration due to gravity, and the change in height of the object. These values can be obtained from the given information about the system or experiment.
How do I apply the conservation of energy principle to find final velocity?
To apply the conservation of energy principle, you need to identify all forms of energy present in the system, such as kinetic energy, potential energy, and thermal energy. Then, calculate the total energy of the system at the beginning and end of the motion. The difference between the two energies will be equal to the work done by the system, which can be used to calculate the final velocity.
Are there any limitations to using conservation of energy to find final velocity?
Yes, there are some limitations to using conservation of energy to find final velocity. This principle assumes that there is no external force acting on the system, and all energy is conserved within the system. In real-world situations, there may be external factors such as air resistance or friction, which can affect the final velocity and should be taken into account for more accurate results.
