MHB How do I find the coordinates of the centre and vertices in a square and circle?
  • Thread starter Thread starter Maths student
To find the coordinates of the center and vertices of a square and circle, the discussion emphasizes the importance of understanding geometric principles rather than rote learning. For the square, the center can be determined by finding the perpendicular line to diagonal BD that passes through vertex A. The circle's center can be calculated using the equation of a circle and the coordinates of points it passes through. Participants express frustration with the complexity of the problems and seek guidance on the calculations. Ultimately, the focus is on grasping the underlying concepts to solve similar problems effectively.
Maths student
1) The vertex A if a square ABCD is at the point (6, -4 ) . The diagnol BD has equation 2y-x=6, and the vertex B is nearer to the origin than D.
a)calculate the coordinates of the centre of the square.
b)calculate the coordinates of B and C.
2) Calculate the coordinates of the centre of the circle that pass through (0,2) , (4,8) and the origin O.
I attempted 1a and 2 and got random answers... which were not on the answers page. I couldn't do b. pls can someone show me the actual working as i can figure the answer on the answers page anyways :P i need to know how to work these out - they're hard :/
Mathematics news on Phys.org
Hi Maths student! Welcome to MHB!
For 1a) how far can you get to find the line perpendicular to BD that contains A?
You will need the answer to 1a) to answer 1b).
For 2), hint: the equation of a circle is $(x-a)^2+(y-b)^2=r^2$, where $r$ is the radius, and (a,b) is the center.
What is the set of equations that you can get by substituting each of the given points for x and y?
For 2) let's denote $O(0,0)$, $A(0,2)$ and $B(4,8)$. As an alternative solution, you could find the intersection of the perpendicular bisectors to $OA$ and $OB$.
Can you help with b?
And how do you know how to do 2? Do I just rote learn the method.. I mean, is that what you did? I don't get it
Rote learning is a bad way to learn math. It's a dead end. Math is about understanding.
But you have come to the right place if you want to learn.
Still, we can only help you if you give us some indication what you know and/or what you are thinking.
So, if you're willing, what are your thoughts on 1a?
I passed last year with an A by rote learning the methods, for all I care. The questions repeat every year with different numbers.
I understood 1a, having been aught on another forum.
I have no clue in regards to b and for 2 I thought that if the same coordinate appearing means the line is the diameter... But obviously not.
I'm tired, it's late and the exam is tomorrow.
Fyi I can't use a calculator so using y minusyone equals mx plus c and the rule about the gradients and parrellr and perpendicular lines, please can you just show your working.
Fyi this isn't homework, just practice for the exam. The answers are in my textbook anyways. I just want to know how you het the answer.
Trust me I also got an A* last year despite teachers thinking I would struggle as I didn't really understand, but just rote learned info.
These exams are only testing your memory if you practice enough questions anyways :p
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation has no solutions with positive integers if It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
