gonzalohiguain
- 1
I want to know how to do this so after I find the equation by hand, I can check to see if I am correct.
To enter a function into your TI-84 calculator, press the "Y=" button and use the arrow keys to navigate to the desired function. Then, use the "=" button to enter the equation and press "Enter" to save it.
To find the derivative of a function on your TI-84 calculator, navigate to the "CALC" menu and select "dy/dx." Enter the function and press "Enter" to see the derivative equation.
Yes, you can find the derivative of a function at a specific point on your TI-84 calculator by using the "dy/dx" feature in the "CALC" menu. Simply enter the function and the desired point and press "Enter" to see the derivative at that point.
To graph the derivative of a function on your TI-84 calculator, enter the function into the "Y=" menu and then navigate to the "MODE" menu. Select "Deriv" and then press "Graph" to see the graph of the derivative.
Yes, you can find the second derivative of a function on your TI-84 calculator by using the "dy2/dx2" feature in the "CALC" menu. Enter the original function and press "Enter" to see the second derivative equation.
