MHB How do I find the Euclidean Coordinate Functions of a parametrized curve?
To find the Euclidean coordinate functions of the parametrized curve α(t) = (cos(t), t^2, 0), the coordinates can be expressed as x = cos(t), y = t^2, and z = 0. The relationship between t and y allows for the substitution t = ±√y, leading to x = cos(√y) for both cases. Since cosine is an even function, the negative root does not change the output, confirming that x = cos(√y) is valid. This approach clarifies the connection between the parameterization and Cartesian coordinates.
banananaz
I've been given a curve α parametrized by t :
α (t) = (cos(t), t^2, 0)
How would I go about finding the euclidean coordinate functions for this curve? I know how to find euclidean coord. fns. for a vector field, but I am a bit confused here.
(Sorry about the formatting)
Mathematics news on Phys.org
I'm not certain what you mean by "Euclidean Coordinates". Perhaps you mean what I would call "Cartesian Coordinates"- a direct relation of x and y. The equations you have are x= cos(t), y= t^2, z= 0. The second equation can be written $t= \pm\sqrt{y}$ so we get two equations, $t= \sqrt{y}$ and $t= -\sqrt{y}$ and then $x= cos(\sqrt{y})$ and $x= cos(-\sqrt{y})$.
But since cosine is an "even function", $cos(-\theta)= cos(\theta)$, those both give $x= cos(\sqrt{y})$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
