How do I find the normal force?
In summary: The force that would be the normal force if the person weren't there.In summary, the problem involves a crate being held stationary against the ceiling with an applied force of 'P'. Newton's first law is used to analyze the forces acting on the crate, including the normal force, gravitational force, and applied force. It is determined that the normal force is equal to mg-P, with some variation in signs depending on the direction of the forces. A force table is used to analyze the components of each force and confirm the magnitude of the normal force. Ultimately, the solution involves understanding the concept of normal force as the opposing force to the applied force.
Gamerex
25
Let's say I'm holding a crate up against the ceiling with a force of 'P', and the crate is stationary.
What is the normal force?
Newton's 1st law: ƩF=0
I have three forces acting on the crate - The normal force, the gravitational force, and the applied force.
According to Newton's first law, Fg+Fn+Fa=0
Thus, Fn=-Fg-Fa
Since Fg pulls down Fg=-mg
Since Fa pushes up, Fa=P
Thus, Fn=mg-P
However, my book says Fn=P-mg. What am I doing wrong?
Fn is pushing downward, so its sign in your force balance equation should be negative.
Why is it I only apply this negative to the normal force? If a downward force is negative, then Fg should be negative too, and
-Fg-Fn+Fa=0
Fn=Fa-Fg=P+mg
Which still isn't the right answer :/
I made a force table that I can use to analyze the component of each force and the net force that results.
Force - y-component
Fg:____-mg
Fa:____+P
Fn:____mg-P?
__________________
ma:____0
Adding the entries in this table, it seems obvious that the normal force must equal mg-P. Otherwise, the sum of this table wouldn't be zero.
OK. Here's my version of it, where the positive direction of force is in the upward direction:
Fa-mg-Fn=0
This gives Fn=P-mg
In these equations Fn stands only for the magnitude of the normal force. The direction of the normal force is downward.
It will be easier to set up the forces so that they are all positive, and you deal with direction explicitly with the signs. Since [itex]F_n[/itex] and [itex]F_g[/itex] are both down, and [itex]F_a[/itex] is up, you should write
[tex]-F_g - F_n + F_a = 0.[/tex]
From which the book's answer comes. Your answer is correct, too, but the value of [itex]F_n[/itex] is then negative.
Edit: Oops, someone beat me to it.
Thus, Fn=-Fg-Fa
Thus, Fn=mg-P
You are both the applied force and the normal force, because the object is directly above you and hence you are 90 degrees from the plane. Thus they are the same force.
If you were on an incline, the normal force can be derived via some basic trig.
Fn = Fw / ( sin(normal angle) + cos(normal angle)*tan(angle elevation)
Fw: Force of weight, in newtons, or pounds, etc.
Normal angle: elevation angle + 90 degrees
Please note that this thread is more than 9 years old. Thank you for your contribution, but it is unlikely to help the original poster with his/her homework this late in the game.
Yes. though if someone were searching for something similar and found this forum, as I had, then perhaps some of these replies, mine or others, will help future seekers.
Fair enough, but unfortunately you have missed what has confused the OP. It is simply a matter of sign convention. In writing Fg+Fn+Fa=0, Gamerex is taking all forces acting on the box as positive up; the book has taken each force as positive in its actual direction, making the normal force positive down.
Summary for the benefit of future help seekers
Without reference to force direction or any equations, one can use a bit of logic to answer this question. Say the person holding the crate lifts it up at constant velocity until it just barely touches the ceiling. Up to that point, the applied force is equal to the crate's weight, ##mg##. The crate cannot be pushed through the ceiling because the ceiling exerts a normal force on it. Any additional increase of the applied force past ##mg##, is matched by the opposing normal force. Thus, the normal force is the applied force less the weight of the crate.
Likes paulimerci
See my comment in post #10.
I saw it before posting #11 which was not meant as a reply or comment to #10 but as an independent summary for the casual visitor to the thread.
Well Fg + Fn = zero when it's vertical. now the Fa has an opposing force, the force from the ceiling pushing back on the person. Do you want to call that Fnc? So that's another normal force. The person holding the object upright is supporting the object exactly with normal force until they apply another force (against the ceiling)
So the person is the normal force, their force applied, Fa if you will, is the force past the normal force. So that's a net applied force, (Fnet = Fa - Fn), is then countered with Fnc. So four forces will equal zero, not three.
We are talking about the forces on the crate. There are 3 entities exerting forces on it:
  1. The Earth exerts force mg down on the crate.
  2. The person exerts force Fapp up on the crate.
  3. The ceiling exerts force Fn down on the crate.
Forces are exerted by entities and you get one force per entity. The difference Fapp - Fn is not a separate force exerted by a fourth entity. It's just a partial sum of the terms that make up the net force.
Likes nasu
I know, I was trying to state that there's a difference - a subtraction. You stated that as well.
I think I merely didn't state it clearly enough. Partial sums calculate up to the entirety of the upward force. It's vector algebra with forces.
I have no idea what you are trying to say, or how it relates to my post.
There is no force from the ceiling pushing against the person for the simple reason that they are not in contact. The force from the ceiling is increased because the person is pushing up, but that's not the same thing. The force exerted by the ceiling is on the box.
In responding to threads created by students, it is important to try to understand and address what specific misunderstanding is blocking them. It may not be that helpful merely to show how to solve the given problem. That is the point of my post #10. Do you understand that post?
Related to How do I find the normal force?
1. What is the normal force?
The normal force is the force exerted by a surface on an object that is in contact with it. It is always perpendicular to the surface and acts to prevent the object from passing through the surface.
2. How do I calculate the normal force?
The normal force can be calculated using the formula FN = mgcosθ, where FN is the normal force, m is the mass of the object, g is the acceleration due to gravity, and θ is the angle between the surface and the direction of gravity.
3. Why is the normal force important?
The normal force is important because it is essential for understanding the motion of objects on inclined planes or surfaces. It also helps to determine the stability and equilibrium of an object.
4. How does the normal force change with the angle of inclination?
The normal force changes with the angle of inclination because as the angle increases, the force of gravity acting on the object also changes. This results in a change in the component of the force that is perpendicular to the surface, which is the normal force.
5. Can the normal force ever be negative?
No, the normal force cannot be negative. It always acts perpendicular to the surface and prevents the object from passing through the surface. If the angle of inclination is greater than 90 degrees, the normal force will be zero, but it cannot be negative.
