How do I find the terminal speed of a body in water?
In summary, the conversation discusses a problem about finding the terminal speed of a baseball in water, given its terminal speed in air and the density of both air and water. The attempt at a solution involves finding a ratio between the terminal velocities in air and water, but this method is not correct due to false assumptions in the problem. The conversation also emphasizes the importance of not just finding the correct answer, but also understanding the problem and the assumptions made.
Ushitha Dissanayake
A baseball has a terminal speed of 42 m/s in air (ρ = 1.2 kg/m^3). What would be its terminal speed in water (ρ = 1.0 x 10^3 kg/m^3)?
A) 0.05 m/s
B) 1.5 m/s
C) 18 m/s
D) 42 m/s
E) 1200 m/s
D=½Cρ*Av^2
where the magnitude of the drag force (D), relative speed = v, drag co-efficient = C, ρ is the air density (mass per volume) and A is the effective cross-sectional area of the body (the area of a cross section taken perpendicular to the
velocity )
v_t=√2*F_g/Cρ*A
where: v_t is the terminal speed, F_g is force gravity, and C, ρ and A is the same as above
Im not sure how to solve this at all, the example that my book gave me involved finding terminal speed by giving me the drag co-efficient as well as the R to find the volume and area for a sphere
I believe this is a badly constructed problem because the obvious way to "solve" it (i.e., comparing the force of gravity on the ball with the drag force of water) is wrong and the proper way of solving it (also taking the buoyancy of the ball into account) requires more information than what is given in the problem (i.e., the density of the ball itself).
Either way, let us solve it the wrong way, which I suspect is what the problem constructor intended. Work symbolically, i.e., do not look for numerical values of middle steps until you reach a final expression. What would be the relation between the terminal velocities in air and water, respectively?
Likes Ushitha Dissanayake
I'm not following
Ushitha Dissanayake said:
I'm not following
This is not helpful. Exactly what are you not following?
I don't really understand what you said
Still not helpful. You need to be specific in what it was you did not understand and why.
"What would be the relation between the terminal velocities in air and water, respectively?" I don't understand what you're implying here
What is the terminal velocities in water and air, respectively? What is the ratio between them? You have already given an expression for the terminal velocity so this should not be hard.
i tried finding a ratio by dividing (ρ = 1.2 kg/m^3) by (ρ = 1.0 x 10^3 kg/m^3) which gave 1.2*10^-3, then multiplying that with the terminal velocity of it in the air which gave 0.0504/ but the answer is 1.5
You are not listening. You cannot just go around randomly constructing ratios and expect other ratios to behave the same way. I asked you to find a very specific ratio by dividing the two expressions you have for the terminal velocity in air and water, respectively.
can you explain why we have to do it this way i still don't understand how this ratio thing works
A ratio is one quantity divided by another. Please use the analytical expressions you have, do not insert numbers. What do you get? It will be much clearer to you if you do it.
thanks for ur explanation
This still does not show that you have gotten the problem correctly. Please write out your solution. Also, as already mentioned, the ”correct” solution relies on false assumptions and we have not yet begun to discuss that. You will not learn properly if you are happy just getting the ”right” answer in these cases. You need to examine the problem assumptions.
Likes CWatters
Related to How do I find the terminal speed of a body in water?
1. What factors affect the terminal speed of a body in water?
The terminal speed of a body in water is affected by several factors, including the density and viscosity of the water, the shape and size of the body, and the gravitational force acting on the body.
2. How do I calculate the terminal speed of a body in water?
The formula for calculating the terminal speed of a body in water is: Vt = (2mg)/ρAC, where Vt is the terminal speed, m is the mass of the body, g is the acceleration due to gravity, ρ is the density of the water, A is the cross-sectional area of the body, and C is the drag coefficient.
3. Can the terminal speed of a body in water be greater than its initial velocity?
No, the terminal speed is the maximum velocity that a body can achieve in a fluid. If the initial velocity of the body is greater than the terminal speed, it will gradually slow down until it reaches the terminal speed.
4. How does the shape of a body affect its terminal speed in water?
The shape of a body can greatly affect its terminal speed in water. A streamlined and aerodynamic shape will have a lower drag coefficient, resulting in a higher terminal speed. On the other hand, a larger and bulkier shape will have a higher drag coefficient, leading to a lower terminal speed.
5. Is the terminal speed of a body in water the same as its terminal velocity in air?
No, the terminal speed of a body in water and its terminal velocity in air are not the same. This is because water is denser and more viscous than air, which affects the drag force acting on the body. Therefore, the terminal speed of a body in water will be lower than its terminal velocity in air.
