How do I go from ∫_0^x f(t) dt to int_g(x)^h(x) f(t) dt?
  • Thread starter s3a
In summary, the conversation is discussing how to use the "historical" version of the Fundamental Theorem of Calculus to obtain the "powerful" version. The equation being used is the chain rule, and the individual is seeking help in understanding how to apply it in this situation.
s3a
818
In other words, I'm trying to use the "historical" version of that part of the Fundamental Theorem of Calculus to obtain the "powerful" version.
Chain rule (I think).
I can't find how to do this in my book, and I have a strong feeling that this involves the chain rule, but I'm not too sure how to get my vague idea into writing, and any help in doing so would be greatly appreciated!
It is best to put the equations in the body of your post, not in the title. If I understand you, you are asking how this equation$$
\frac d {dx}\int_a^x f(t)~dt = f(x)$$implies the more general Leibnitz rule. You are correct that it involves the chain rule. For example say we want to differentiate$$
F(x) = \int_a ^{h(x)} f(t)~dt$$Here, you can let ##u = h(x)## so ##F(x) = \int_a^u f(t)~dt##. Then using the chain rule:$$
F'(x) = \frac{dF}{du}\cdot \frac{du}{dx}=f(u)\cdot \frac{du}{dx}=f(h(x))h'(x)$$The lower limit is treated similarly.
Likes 1 person
Edit: Sorry, I double-posted.
Thanks for the answer.
Your assumption as to what I am asking is correct, and I agree that I should have also added the algebraic expressions in the body of the opening post, so I will add it there there as soon as this message has been posted.
From what you said, I don't understand how to justify replacing x with h(x). I get that h(x) = x is valid (because h is a function of x and x is such a function), but I don't see how we can assume that h(x) can be a function of x that is not just x.
Could you please explain the reasoning as to why the first equation you gave implies that all other functions of x (that are not just x) can be considered on the upper limit of integration for the second equation you gave?
I can hardly make sense of this response. I didn't "replace" ##x## with ##h(x)##. There is no law against writing a definite integral with variables in the limits, nor differentiating such an expression. You asked how to derive the differentiation formula for such a problem and I showed you.
What is the problem? The Fundamental Theorem says that if ##F## is an antiderivative of ##f##, then
[tex] \int_0^{\text{anything not containing}\,t} f(t) \, dt =
F(\text{anything not containing}\,t) - F(0).[/tex]
Ray Vickson, my problem is (or was?) that I don't see how LUKurtz's first equation (in his first post), is saying that the upper limit of integration is “anything not containing t”.
It seems that what you guys are saying is that what was done was simply to recognize that it is just a general concept of integrals that anything that does not involve the variable being integrated can be in the limits of integration, and that there was not any kind of algebraic manipulation on the upper limit of integration, x, of the first equation LCKurtz gave (in first post), such that all that mattered from the first equation LCKurtz gave (in his first post), was merely to establish a relationship between differential and integral calculus.
Is this correct?
Is this correct?
I cannot figure out what you are asking. Anyway, you have been given the answers to your original question.
Sorry for being difficult to understand.
I can't be 100% sure, but I think I understood what I should be doing.
Thank you both for the help.
FAQ: How do I go from ∫_0^x f(t) dt to int_g(x)^h(x) f(t) dt?
How do I find the limits of integration when converting from a definite integral to an indefinite integral?
When converting from a definite integral, where the limits of integration are given, to an indefinite integral, where the limits of integration are not given, you can use the same limits of integration given in the original definite integral. Alternatively, you can use the variable x as the upper limit of integration and a constant as the lower limit, such as 0 or -1.
How do I change the function being integrated when converting from a definite integral to an indefinite integral?
To change the function being integrated, you can rewrite the function being integrated in terms of the variable x. This may involve using algebraic manipulations or substitutions. Once the function is in terms of x, you can integrate it with respect to x to obtain an indefinite integral.
What is the difference between a definite and indefinite integral?
A definite integral has specific limits of integration and gives a numerical value as the result. An indefinite integral does not have specific limits of integration and is represented by an antiderivative, which is a function.
Can I use different limits of integration when converting from a definite integral to an indefinite integral?
Yes, you can use different limits of integration when converting from a definite integral to an indefinite integral. This may be necessary if the original definite integral has limits that do not work well with integration or if you want to evaluate the indefinite integral at a specific value of x.
How do I evaluate the indefinite integral once I have converted it from a definite integral?
To evaluate the indefinite integral, you can use the rules of integration, such as the power rule or substitution. Plug in the limits of integration if given, or evaluate the antiderivative at a specific value of x if desired.
