How do I graph this inequality?
In summary, the student is asking for a thermal cycle that meets the following requirements: -The cycle lasts for 15 hours-The temperature starts out at 300 degrees C and gradually increases to 500 degrees C-The temperature then rapidly increases and decreases for the first few hours-The temperature gradually cools for several hours and smoothly approaches 100 degrees
babygotjack5
The possible solution to a problem I've been working on is this:
f(x)=100<200/3x+300<500<200*sin(2x)+300<33.33333x+600
note that all the < are actually less than or equal to.
could someone show me exactly how to get this graph and/or what it looks like? I would really appreciate it :)
Welcome to the PF. Your notation seems a little off to me. f(x) does not equal what you have shown as the right hand side(s) (RHS). If you take away the f(x)=, then you have an inequality that you can plot and find the solution for.
So if you take a piece of xy graph paper (or a graphing calculator or Excel or whatever), and graph the 5 functions:
f(x) = 100
f(x) = 200/(3x+300)
f(x) = 500
f(x) = 200*sin(2x)+300
f(x) = 33.33333x+600
What is the region that satisfies the inequalities?
Thanks berkeman :)
I'm not sure if I'm doing this right at all anymore. The idea was supposed to be to have a function that started at 300 and gradually increasing to 500 so the peak would be (3,500). Then it was supposed to fluctuate up and down rapidly as it approached y=100 at x=15.
So, my thought was that if the function was linear until (3,500) and became sinusoidal (I thought about it last night and it will probably have to be a cos, whatever) from there on out, it could "bounce" off the lines y=33.333x+600 and y=100, making it so it would fluctuate more and more as it approached (15,100). Is there a way to make it do this and not have a piecewise function? Part of my assignment is to have it be a single formula, hence all the inequalities together. :)
Would this be better described as an affine transformation or something else using matrices?
Thank you again :)
babygotjack5 said:
Thanks berkeman :)
Thank you again :)
Can you please post the original question in its entirety? A lot is being lost in the translation and transcription.
It now sounds like you are given a piecewise function (not an inequality), and asked to formulate a single equation representing the same? That can be done using step funtions with offsets on the horizontal axis, if needed.
Oops, sorry that it took so long to reply (thanksgiving craziness...you know)
anyways, the question is this:
design a new thermal cycle for a heat treatment system using processes such as annealing, quenching, and tempering. This treatment must fit the following requirements:
Last 15 hours
Oven starts at 300 degrees C
Oven ends at 100 degrees C
The temperature must gradually increase for the first few hours until it reaches 500 degrees
Then it must dramatically and rapidly go up and down in temperature.
Finally, it must gradually cool for several hours and smoothly approach 100 degrees.
Note that it can only increase in temperature at a rate of 3 degrees per minute, and it can cool at 5 degrees per minute BUT the rate of change should not be above 4 degrees per minute per 10 minutes.
does what I suggested make sense with this? Have the function start out linearly and then become sinusoidal at 3 hours and then have this sinusoidal line reflect between the line sloped to equal 100 degrees at 15 hours and a horizontal line on the bottom that is equal to 100? Or more importantly, is there any way to make a sinusoidal line that kind of "bounces" off other lines kind of like how the absolute value of a line gets to zero and then "bounces" in a perpendicular slope?
FAQ: How do I graph this inequality?
What is an inequality?
An inequality is a mathematical statement that compares two quantities using symbols such as <, >, ≤, or ≥. It shows the relationship between the two quantities and indicates which one is larger or smaller.
How do I graph an inequality?
To graph an inequality, you first need to determine the boundary line by replacing the inequality symbol with an equal sign and graphing it as a solid line if the symbol is ≤ or ≥, or a dotted line if the symbol is < or >. Then, choose a test point that is not on the boundary line and plug it into the inequality. If the test point makes the inequality true, shade the region that contains the test point. If it makes the inequality false, shade the other region.
What is the difference between graphing an inequality and graphing an equation?
The main difference between graphing an inequality and an equation is that an inequality shows a range of solutions, while an equation only has one specific solution. Inequalities also use shading to represent the solution set, while equations use a single point on the graph.
Can you help me solve an inequality using a graph?
Yes, graphing an inequality can be a helpful way to solve it. By graphing the inequality, you can visually see the solution set and determine the range of possible solutions. This can be particularly useful for inequalities with multiple variables.
What are some common mistakes to avoid when graphing an inequality?
Some common mistakes to avoid when graphing an inequality include not properly identifying the boundary line, choosing the wrong test point, and shading the incorrect region. It is also important to pay attention to the direction of the inequality symbol, as this can change the direction in which the region is shaded.
