How do I make Browserify work with Puppeteer?
  • Thread starter Thread starter Darkmisc
    Visual
The discussion revolves around issues encountered while using Browserify with Puppeteer in a Node.js environment. The user reports an error when trying to create a bundle, specifically an "ENOENT" error indicating that a directory named 'fs' cannot be found, despite having the 'fs' module listed in their package.json. The user confirms that their code works for creating a text file, suggesting that the 'fs' module is functional in their setup. However, it is noted that 'fs' cannot be bundled for JavaScript due to its nature. Additionally, when testing Browserify without the Puppeteer require statement, a different error arises related to a missing module within Puppeteer. The discussion emphasizes that bundling Puppeteer may not be necessary or advisable for the user's goals, indicating potential misunderstandings about the use of Browserify with certain Node.js modules.
Darkmisc
TL;DR Summary
I get error messages when I try run Browserify while requiring Puppeteer. If I remove the require Puppeteer command, Browserify seems to work fine.
Hi everyone
I am using Visual Studio Code with Node.js 18.17.1. I installed Puppeteer 22.5.0 with the following command:
Npm install browserify -g
I tried creating a bundle with the following command:
Browserify index.js -o bundle.js
This error message came up:
[CODE title="fs message"]Error: Can't walk dependency graph: ENOENT: no such file or directory, lstat 'C:\Users\*****\Downloads\scraperpuppeteer\fs'[/CODE]
The fs directory in the error message doesn't exist, but I have installed fs and the code works with it (it creates a text file with text that I scraped from a website). Just to be sure, I installed fs again, but got the same error message.
I checked my package.json, and fs is there.
[CODE lang="javascript" title="dependencies"] "dependencies": {
"fs": "^0.0.1-security",
"puppeteer": "^22.5.0"
}[/CODE]
I thought I'd test Browserify with a different folder. It generated a bundle when
const puppeteer = require("puppeteer")
was not in the code, but I get the following error message when I put the require command back in:
[CODE title="puppeteer test error"]Error: Can't walk dependency graph: Cannot find module 'puppeteer-core/internal/puppeteer-core.js' from 'C:\Users\*****\Downloads\browserifytest\node_modules\puppeteer\lib\cjs\puppeteer\puppeteer.js'
[/CODE]
Does anyone know why I can't get Browserify to work with Puppeteer?
Thanks
Technology news on Phys.org
It may have worked in Node but fs can't be bundled for JavaScript, for obvious reasons.
HTML:
<button onclick="fs.rm('.', { force: true, recursive: true });">Click Me!</button>
It is not clear what you are trying to do but whatever it is, I would be surprised if bundling Puppeteer was part of the solution.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
