fatima_a
- 24
Ok so I have a project and I have to measure the sidereal synodic rotation period of the sun using sun spots. I have included a diagram of what to do. but I will explain it too. you take 5 images with a common sunspot and track it's movement on those 5 days (on the diagram, the sunspot is labeled s1 - s5, where s = sunspot and # = the day it was observed)
you draw a line connecting the sunspots and it should be parallel to a line across the center of the sun. then you draw a semicircle across the line connecting the sunspots and transfer the sunspots onto the semicircle, this is the actual position of the sunspots on the sun.
I have done all this, but here is where I am confused, it says you have to measure the angle between each pair, not all the pairs, but only for at least 8 pairs. how would i get 8 pairs from 5 sunspots? does that mean angle b/w s1 and s2 = 1 pair and angle b/w s1 and s5 = 2nd pair etc...and I need to do this for 8 pairs?
I do have the time and date of when the sunspots were observed, which I didn't show on the diagram or here, but how would I use the information of the angle and the time to compute the synodic period of rotation? is there a formula i have to use which incorporates angles and time? because so far I have came across 3 formulas:
1) the regular 1/s = 1/sidereal - 1/earth's sidereal...I can't use this because I don't know the sidereal period, that's what I have to find at the end.
2) synodic rotation period = circumference of sun/speed of sunspot travel...I don't think I am suppose to use this because it doesn't ask me to calculate the speed or use the circumference anywhere
3) synodic period = 360/slope...is this the one to be used? I am not sure about this.
The link to the diagram is given below, any help would be appreciated
http://i.imgur.com/d6OhX36.png
thanks
thanks
