MHB How do I merge two age groups per 10k from an abortion rate table?
To calculate the abortion rate for the age group 12-19, the discussion involves merging the rates of the 12-17 and 18-19 age groups. The initial calculation yielded a rate of approximately 125.67 per 10,000 women, derived by combining the number of abortions and women in each age group. However, further analysis suggested a more accurate combined rate of about 105.4 per 10,000 women based on total abortions and surveyed women. There is uncertainty regarding the meaning of the "Distribution of abortion age" column, which may impact the calculations if it represents the percentage of total women surveyed. Ultimately, the combined rate could also be interpreted as approximately 162.4 per 10,000, depending on the interpretation of the distribution data.
samlag
  • I would like to find the 12 to 19 abortion rate per 10,000 women from the following table:
This would be the merging of age groups "12-17" with "18-19" to some how get the 12-19 abortion rate.
EDIT: "Distribution of abortion age" was translated from "Répartition des ges l'avortement" in French. It appears to me to be the percentage each age group's abortions are of the total amount of abortions.
The answer I came up with is 125.67 per 10,000. Not sure if that is correct.
I multiplied the rate per individual woman by the number of abortions for each group which I think gave the number of women. I added both of these groups together. I added both groups number of abortions and then divided the amount of women by amount of abortions and multiplied it by 10,000.
If you would like to answer, its probably best to focus on the math, and not politics :)
Mathematics news on Phys.org
Let us introduce some notations. Let age 12-17 be denoted by index 1 and age 18-19 by index 2. Let $a_i$ be the number of abortions and $r_i$ be rates for $i=1,2$. Let us express rates as absolute fractions (abortions per woman) rather than numbers per 10,000. Thus, $r_1=60.7/10,000=0.00607$. Let $w_i$ be the total number of women surveyed in each age group. Then $w_i\cdot r_i=a_i$ from where $w_i=\frac{a_i}{r_i}$. We get the following values.
\begin{align}
a_1&=10428 & r_1&=0.00607 & w_1&=a_1/r_1\approx 1,717,627\\
a_2&=13654 & r_2&=0.02409 & w_2&=a_2/r_2\approx 566,791
\end{align}
From the above, it seems that one must divide the number of abortions by the rate.
Here I agree. The combined rate is $$\frac{a_1+a_2}{w_1+w_2}=\frac{a_1+a_2}{a_1/r_1+a_2/r_2}\approx 0.01054$$, or 105.4 per 10,000 women.
However, I am not sure what the third column, "Distribution of abortion age", means. Let us denote it by $d_i$ so that $d_1=6.4$ and $d_2=8.3$. If it is the fraction of total women surveyed in the given age bracket, then these numbers contradict our findings. In this case $w_2/w_1$ should equal $d_2/d_1$, which is not the case for the numbers above. If, however, this is true, then the combined rate equals $$\frac{d_1r_1+d_2r_2}{d_1+d_2}\approx162.4$$ per 10,000.
Note that 10426 / 163652 = 6.4%.
It's the distribution of the abortions over the age groups as a percentage.
However, I am not sure what the third column, "Distribution of abortion age", means. Let us denote it by $d_i$ so that $d_1=6.4$ and $d_2=8.3$. If it is the fraction of total women surveyed in the given age bracket, then these numbers contradict out findings. In this case $w_2/w_1$ should equal $d_2/d_1$, which is not the case for the numbers above. If, however, this is true, then the combined rate equals $$\frac{d_1r_1+d_2r_2}{d_1+d_2}\approx162.4$$ per 10,000.
"Distribution of abortion age" was translated from French "Répartition des ges l'avortement" which also translates to "Распределение мест абортов" and "Zetelverdeling abortus" in Dutch. It appears to me to be the percentage each age group is of the total amount of abortions.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
