How do I replace bearings in a jackshaft?
  • Thread starter Thread starter remush
To replace bearings in a jackshaft housing, first identify the bearings, likely deep groove ball bearings with dimensions ID 15mm, OD 28mm, and width 7cm, possibly part number 6902. Check for any retaining clips before disassembly. Use a small press, available at local workshops, to push the shaft out and remove the bearings without damaging them. If using improvised tools, be cautious to avoid damaging the shaft or housing. Heating the aluminum housing can help ease the removal of tight-fitting bearings. For guidance, consider searching for instructional videos online.
remush
Hi all,
I need advice in how to replace bearings in a jackshaft housing.
The housing is about 9cm long, and is made out of Aluminium.
It has cups at each end with bearings currently fitted that need replacing.
There is a hardened solid steel shaft running through the inside of the bearings, that protrudes about 4 to 5 cm each side.
the shaft is 15mm thick.
Here's an example of something similar, except my jackshaft is just a cylinder.
example
The bearings are ID 15mm OD 28mm 7cm wide.
The shaft to bearings is a press fit, or what is sometimes called a interference fit.
I have no special tools at home to do the job. The jackshaft is a part of a mid drive electric bicycle kit, mounted on a bicycle I use as a food courier. I've found a few workshops that will take on the job but the wait time is 1 to 2 weeks, time that I wont be earning money.
Advice and suggestions welcomed and appreciated
Thank You
Welcome to PF.
The bearings are probably deep groove ball bearings.
Can you read the part number and suffix?
ID 15mm, OD 28mm, 7cm wide, is probably a commodity part number 6902.
The suffix will identify the seals, probably 6902-RR or 6902-2R meaning rubber lip seals.
They will be really cheap from any bearing supplier.
To dismantle the unit, first check for and remove spring retaining clips. See if you can find a lawn mower, bike or car mechanic workshop with a small press you can use. You will have to put the assembly in some sort of press, that will push the shaft out with one bearing. Then push that bearing from the shaft, and the other from the housing.
Assembly is the opposite sequence, but you must press only on the bearing rings that are a tight fit, so you do not bruise the bearings.
If you do the job with a hammer and old water pipes, and it goes wrong, you will have to buy more bearings. Take care not to dent the shaft or fracture the aluminium casing. If the bearings are a tight fit in the casing, warm it all up so the aluminium expands and the fit is easier.
Search YouTube for a video.
Likes Nik_2213, Tom.G, jack action and 1 other person
The idea is to use water to shift the centre of gravity of the pendulum by a small amount. The pendulum rod will have a tube closed at the bottom and open at the top. A second similar tube will be mounted nearby and will act as a reservoir. The water will be transferred using a peristaltic pump driven by a stepper motor and will travel via a thin flexible silicon tube. A loop arrangement will minimise friction at the pendulum's fulcrum. The silicon tube will extend to the bottom of the...
Philips Hue was the very first provider of smart LED bulbs that can be controlled wirelessly. Over the years, as Philips sold ever improved models of smartbulbs, it became very difficult to identify exactly which model one of their bulbs is. Once I've installed a smart bulb, there is some additional information in the Hue app about the bulb model, but even then, I found that it requires information from both the app and from what's printed on the outside of bulb to be sure what the actual...
Some time ago I posted this Raspberry PI DIY Mass Spec using Raman Scattering. It's was something of a cumbersome project though, needing a 3D printer and special heat-resistant plastic giving of carcinogenic fumes during printing. To be blunt it was also not very mobile and interpreting the results was further cumbersome Recently though, I've been told that Arduino, and it's various sensor packages, has matured to the point where it's a usable alternative. Now I realize that a cigarette...
