MHB How do I rewrite expressions using absolute value?
  • Thread starter Thread starter mathdad
    Absolute
The absolute value definition states that |x| equals x for non-negative x and -x for negative x. An example provided involves rewriting the expression |1 - sqrt{2}| + 1. Since 1 - sqrt{2} is negative, it is rewritten as -(1 - sqrt{2}) + 1. This simplifies to -1 + sqrt{2} + 1, resulting in sqrt{2}. The final answer is confirmed as correct.
mathdad
The definition of absolute value states the following:
| x | = x when x is > or = 0
| x | = -x when x < 0
I can use the above definition to rewrite expressions that do not contain absolute values.
| 1 - sqrt{2} | + 1
The value 1 - sqrt{2} is less than 0.
So, we have -(1 - sqrt{2}) + 1.
-1 + sqrt{2} + 1
Answer: sqrt{2}
Correct?
Mathematics news on Phys.org
Yes, this is correct.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
