How do I show two planes are neither coincident, or parallel?
In summary, the problem statement asks for a proof that two planes with given normals are neither coincident, parallel, nor distinct. However, it is not possible to prove this since two planes in three-dimensional space must be either parallel or coincident. The solution set of the system of equations for the planes can determine whether they are parallel, coincident, or intersect in a line.
Random-Hero-
40
Show that the two planes are neither coincident, parallel, nor distinct. Identify, geometrically, how the planes intersect and determine the angle between the two planes to the nearest degree.
[tex]\pi[/tex]1: x + 2y - 4z + 7 = 0
[tex]\pi[/tex]2: 2x - 2y - 5z + 10 = 0
I found the normals to be
n1 = (1, 2, -4)
n2 = (2, -2, -5)
Two planes, if they intersect, intersect in a line.
An equation of a plane has the form
nxx + nyy + nzz = d
where \vec n = <nx,ny,nz> is the normal vector to the plane.
It can be shown that the angle between two planes' normal vector equals the angle between the planes. You can use the dot product
\vec n1 dot \vec n2 = |n1||n2|cos(\theta)
But how do I like...SHOW that they aren't either of those without drawing a diagram? Because it looks like like the first part of the question wants me to SHOW they are neither parallel or coincident, and the second part is finding the angle. So how would I show that they are neither parallel or coincident without proving the angle? All I can really think of is the fact that n2 [tex]\neq[/tex]kn1[tex]\pi[/tex]
Well, parallel planes don't intersect, so finding an intersection proves they're not parallel, right? Coincident planes lie on top of one another so showing that they intersect in a line proves that they aren't coincident. But, aren't these two planes distinct, or am I thinking of something else.
I think that maybe my professor just made a typo, because that doesn't make sense, from everything I've found so far, suggest they are distinct. But how do I show that? Do I use the dot/cross product for the parallel and perpendicular things?
I agree. The problem statement is incorrect. Two planes in three-dimensional space (as yours are) must be either parallel or coincident. If they are parallel, they are distinct. If they intersection in a line, I would say that they are distinct, since we can tell them apart, but maybe your prof means distinct in the sense that they share no points at all.
The two planes you are given have different normals, so they must intersect in a line, so it's not possible to prove that they are not parallel, not coincident, and not distinct. It's a little like saying, n is a positive integer - prove that it is not even and not odd.
an inhomogenous system of two equations in three unknowns of the form Ax=b. look at the solution set of this system. if there are no solutions, then the two planes are parallel. if the solution set is a plane, then the two planes are coincident. if the solution set is a line, then the two planes intersect in a line and cannot be distinct (no points of intersection, if i interpret this correctly). it is impossible for the solution set to be a point for a 2x3 system. hope this helps.
FAQ: How do I show two planes are neither coincident, or parallel?
How do I determine if two planes are coincident?
To determine if two planes are coincident, you need to check if they have the same normal vector and if a point on one plane satisfies the equation of the other plane. If both conditions are met, the planes are coincident.
How can I show that two planes are not parallel?
To show that two planes are not parallel, you can find the angle between their normal vectors. If the angle is not 0 or 180 degrees, then the planes are not parallel. Another way is to find the intersection line of the two planes. If the intersection line exists, then the planes are not parallel.
What is the difference between parallel and coincident planes?
Parallel planes have the same slope or inclination, which means they never intersect. On the other hand, coincident planes have the same normal vector and intersect at every point, which means they are essentially the same plane.
Can two planes be neither parallel nor coincident?
Yes, two planes can be neither parallel nor coincident. In this case, the planes intersect at a single line. This relationship is known as skew planes.
How many points of intersection do non-parallel planes have?
Non-parallel planes can have one point of intersection or an infinite number of points if they are coincident. If the planes are not parallel but not coincident, they will have exactly one point of intersection.
11K
