MHB How do I sketch the reflection of line segment AB about the line y = x?
  • Thread starter Thread starter mathdad
    Reflection
To sketch the reflection of line segment AB about the line y = x, the coordinates of the endpoints must be swapped. The endpoints of line segment AB are given as (-1, -2) and (-5, -2). The reflection points A' and B' can be found by switching the x and y coordinates of the original points, resulting in A' at (-2, -1) and B' at (-2, -5). The line y = x serves as the perpendicular bisector for the segments connecting A to A' and B to B'. This process confirms the correct method for reflecting points across the line y = x.
mathdad
The endpoints of line AB are given to be (-1, -2) and
(-5, -2). Sketch the reflection of line segment AB about the line y = x.
As I understand this concept, I must show that the line y = x is the perpendicular bisector of the line segment AB.
Two points are given. This tells me to find the slope m.
m = (-2 - (-2))/(-5 - (-1))
m = (-2 + 2)/(-5 + 1)
m = 0/-4
m = 0
When m = 0, we are talking about a horizontal line.
Where do I go from here?
Mathematics news on Phys.org
A reflection about the line $y=x$ simply requires swapping the $x$ and $y$ coordinates.
To see why this is true, consider a point in the plane $\left(x_1,y_1\right)$. Its distance $d$ to the line $y=x$ is given by:
$$d=\frac{\left|x_1-y_1\right|}{\sqrt{2}}$$
So, we want to find the other point $\left(x_1,y_1\right)$ with the same distance, only on the other side of $y=x$, that lies along the line:
$$y=-(x-x_1)+y_1$$
Hence:
$$y_2-y_1=x_1-x_2\tag{1}$$
$$d=\frac{\left|x_2-y_2\right|}{\sqrt{2}}$$
This gives us two cases:
i) $$x_2-y_2=x_1-y_1\implies y_2-y_1=x_2-x_1$$
Adding this to (1), we find:
$$y_1=y_2$$
This means we have the original point, so we discard this.
ii) $$x_2-y_2=y_1-x_1\implies y_2+y_1=x_2+x_1$$
$$y_2=x_1\implies x_2=y_1$$
Thus, we find the reflection of $\left(x_1,y_1\right)$ about the line $y=x$ is the point $\left(y_1,x_1\right)$.
$$y=-(x-x_1)+y_1$$
Hence:
$$y_1=y_2$$
Do I switch the original coodinates of the given points, plot the points on the xy-plane and then connect them with a straight line?
Yes. (Yes)
Well, there's your problem- you understand wrong. You need to find two new points, A' and B', such y= x is the perpendicular bisector of both the line segment from A to A' and the line segment from B to B'.
If A were (x, y) and B were (y, x), that is, if A were something like (2, 3) and B were (3, 2), then y= x would be the perpendicular bisector of AB.
m = 0/-4
m = 0
I know what to do thanks to Mark.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
