How do I solve: p(t)f''(t)+q(t)f'(t)=Kf(t) ?
  • Thread starter Thread starter simplex
The equation p(t)f''(t) + q(t)f'(t) = Kf(t) is a linear homogeneous differential equation derived from a physics problem, where p(t) and q(t) are periodic functions. The discussion suggests using Fourier series, specifically the complex exponential form, to find solutions for f(t) and determine the values of the constant K. It is noted that for stability, K can take a wide range of values, but for steady-state solutions, it must be discrete. The existence of solutions for f(t) varies depending on the intervals of K, with specific ranges indicating whether solutions exist or not. The conversation emphasizes the importance of understanding the implications of K on system stability and solution existence.
simplex
How do I solve the equation: p(t)f''(t)+q(t)f'(t)=Kf(t) ?
I have the equation: p(t)f''(t)+q(t)f'(t)=Kf(t) that results from a problem of physics.
- p(t) and q(t) are two known periodical functions of period T
- f(t) is an unknown function
- K is an unknown constant
What I need is to determine all the possible values of these K constants with the intention of finding the real ones if they exists.
Have you tried Fourier series like this?
f(t) = \sum {a_n cos(\frac{n\pi t}{T})+b_n sin(\frac{n\pi t}{T})
Note that the fundamental frequency of the above series is half of that of p(t) and q(t).
If we let y(t)=f(t) then your equation is a linear homogeneous DE.
p(t)y''+q(t)y' - Ky = 0.
But you are not particularly interested with the solution f(t), aren't you ?
The existence theorem may be useful here I think! What is the initial condition?
Out of curiousity, where's the physics? This is math.
flatmaster said:
I agree with wywrong in attempting a Fourier series solution. However, I would use the complex exponential form of the Sin and Cos to make your math cleaner.
Flatmaster is right. Complex exponential form is better. And I think whatever k's value is, there is a general solution of the form
f(t)=\sum{a_n e^{(r_n+in\omega)t}}
where \omega=\pi/T.
For r_n<0, those components will die down. If there are r_n>0, the system will be unstable as those components will increase exponentially. For frequency components with r_n=0, they will be the steady state solutions. To be stable, k can assume a large range of values. To have steady state solutions, k can only assume discrete values. For those k's any slight change in k or p or q may render the system unstable, unless your system is non-linear beyond certain amplitude.
P.S. My username is wywong, not wywrong B:).
Thank you. Your idea with using Fourier series was good. Finally I investigated this method (reading documentation on the internet) and I come up with continuous domains of K for which the equality p(t)f''(t)+q(t)f'(t)=Kf(t) can take place.
For instance if:
K=[0 1] -> f(t) exists and it is not zero
K=(1 4] -> f(t) does not exists
K=(4-8] -> f(t) exists and it is not zero
  • · Replies 17 ·
