How do I solve the Diophantine equation $4x+51y=9$?
  • Thread starter Thread starter Ackbach
To solve the Diophantine equation $4x + 51y = 9$, one must find integer values for x and y that satisfy the equation. The general approach involves using the Extended Euclidean Algorithm to express the greatest common divisor of 4 and 51 as a linear combination of these coefficients. The solution can then be adjusted to find specific integer solutions. Kaliprasad successfully provided two correct solutions to the problem, demonstrating effective methods for tackling such equations. This discussion emphasizes the importance of understanding the underlying principles of Diophantine equations.
Ackbach
MHB
Here is this week's POTW:
Solve the Diophantine equation $4x+51y=9$.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to kaliprasad for two correct solutions. I post one of them here for you:
Because $\gcd(51,4)=1,$ a solution exists for the same.
Find $1$ as a combination of $51$ and $4$ using the Extended Euclidean Algorithm:
$51=12∗4+3$ or $3=51−12∗4$
$4=3∗1+1$ or $1=4−3=4−(51−12∗4)=13∗4−51∗1$
So $9= 4 * 2 + 1 = 4 * 2 + (13 * 4 - 1 * 51) = 15 * 4 - 1 *51$.
So $x = 15, y = -1$ is a solution of the same, as $51 * 4 - 4 * 51 = 0$; so adding $51t$ to $x$ and subtracting $4t$ from $y$ will not change $4x+51y$. So $x=15+51t$, $y=−1−4t$ is the solution set, where $t$ is any integer.
