How do I solve the following limit?
  • Thread starter BrainFood
  • Tags
    Limit
In summary, a limit is a fundamental concept in calculus that describes the behavior of a function as its input approaches a certain value. To solve a limit algebraically, you can use techniques such as simplifying the function or applying algebraic rules. There are two types of limits, one-sided and two-sided, which differ in the direction of the approaching input. You can also solve a limit using the graph of a function by visually identifying the value it approaches or using the concept of continuity. However, there are special cases and exceptions when solving limits, such as undefined limits, infinite limits, or discontinuities.
BrainFood
Could someone run me through how to solve this please? I am stuck.
[itex]\displaystyle\lim_{x\rightarrow \infty} {\frac{3x+5}{x-4}}[/itex]​
I worked it out. Never mind.
For others who might be interested, the simples thing to do is divide both numerator and denominator by "x":
[tex]\lim_{x\to\infty} \frac{3x+ 5}{x- 4}= \frac{3+ \frac{5}{x}}{1- \frac{4}{x}}[/tex]
Now, as x goes to infinity, the terms with x in the denominator go to 0.
FAQ: How do I solve the following limit?
1. What is a limit?
A limit is a fundamental concept in calculus that describes the behavior of a function as its input approaches a certain value. It represents the value that the function approaches, but may not necessarily reach, at that specific input.
2. How do I solve a limit algebraically?
To solve a limit algebraically, you can try to simplify the function or use algebraic techniques such as factoring, rationalizing, or using trigonometric identities. You can also use the properties of limits, such as the sum, difference, product, and quotient rules.
3. What is the difference between a one-sided limit and a two-sided limit?
A one-sided limit only considers the behavior of a function as its input approaches the given value from one direction, either the left or the right. A two-sided limit, on the other hand, considers the behavior of the function as its input approaches the given value from both the left and the right.
4. How do I solve a limit using the graph of a function?
You can solve a limit using the graph of a function by visually identifying the value that the function approaches as its input gets closer and closer to the given value. You can also use the concept of continuity to determine the value of the limit at a point.
5. Are there any special cases or exceptions when solving limits?
Yes, there are some special cases and exceptions when solving limits. For example, limits can be undefined or have a different value from the left and the right, which is known as a limit does not exist. Also, some functions may have infinite limits or behave differently at certain points, such as discontinuities.
