Brunno
- 80
Somebody can help me with thi following problem:
[tex]\sqrt{n}[/tex] - [tex]\sqrt{n-1}[/tex] < 0,01
Answer: n=2501
An inequation is a mathematical statement in which two expressions are not equal. Instead, one expression is greater than or less than the other.
To solve an inequation, you must isolate the variable on one side of the inequality sign and use inverse operations to simplify the expression. The solution is any value that satisfies the inequality.
Equations have an equal sign, indicating that the two expressions on either side are equal. Inequations, on the other hand, use inequality symbols (<, >, ≤, ≥) to show that the two expressions are not equal.
A solution is valid if it satisfies the given inequality. This means that when the solution is substituted into the expression, the inequality is true. If the solution makes the inequality false, then it is not a valid solution.
Yes, an inequation can have multiple solutions. This is because there are infinitely many numbers that can satisfy the given inequality. The solution set for an inequation is often represented using interval notation.
