How Do I Take the Dot Product of a Complex Expression with Itself?
In summary: MIT = Massachusetts Institute of Technology.As a note, I have shown that \(\frac{1}{\rho} = \frac{\lvert\dot{\mathbf{r}}\times \ddot{\mathbf{r}}\rvert} {\lvert\dot{\mathbf{r}}\rvert^3}\)Here is what I worked out.\begin{align} \frac{1}{\tau} &= -\hat{\mathbf{n}}\cdot \frac{d\hat{\mathbf{b}}}{ds}\\ &= -\rho\frac{d^2\mathbf{r}}{ds^2}\cdot
Dustinsfl
2,281
\frac{(\dot{\mathbf{r}}\times\ddot{\mathbf{r}}) \times\dot{\mathbf{r}}}{\lvert\dot{\mathbf{r}}
\rvert\lvert\dot{\mathbf{r}}\times\ddot{\mathbf{r}}\rvert}
How do I take that dot product of the expression of above with itself?
Let's define $\mathbf a = \dot{\mathbf r},\ \mathbf b = \ddot{\mathbf r}$.
Then, if I understand you correctly, you're asking for:
$$((\mathbf a \times \mathbf b) \times \mathbf a)^2$$
According to the vector triple product we have:
$$(\mathbf a \times \mathbf b) \times \mathbf a = \mathbf b(\mathbf a \cdot \mathbf a) - \mathbf a (\mathbf a \cdot \mathbf b)$$
So:
$$((\mathbf a \times \mathbf b) \times \mathbf a)^2 = a^2b^2 - a^2 (\mathbf a \cdot \mathbf b)^2$$
So:
I really need to get back
\cdot\dddot{\mathbf{r}}}{ \lvert\dot{\mathbf{r}}\times
\ddot{\mathbf{r}}\rvert^2}
afterwards though. I don't see how I can arrange your solution to do the job.
It appears I simply do not understand your question.
Perhaps you can clarify.
It is related to proving the last theorem here:
http://www.math.wisc.edu/~seeger/234/frenet.pdf
which has to do with this questions here:
http://mathhelpboards.com/advanced-applied-mathematics-16/frenet-equation-torsion-6229.html
I see that document also provides the proof for the last theorem...
Is there a step that you do not understand?
I am not using there method. I was just showing you intent.
How is MIT going from step 2 to 3?
http://img13.imageshack.us/img13/184/r6oe.png
What is MIT?
Assuming you mean the 2nd equality, they are using that:
\begin{aligned}
\mathbf T(s) &= \mathbf r'(s) \\
\mathbf T'(s) &= \kappa(s) \mathbf n(s) \\
\mathbf n(s) &= \frac{\mathbf r''(s)}{\kappa(s)} \\
\mathbf b(s) &= \mathbf T(s) \times \mathbf n(s) \\
\end{aligned}
Or if you meant the 3rd equality, it is explained on page 2 in your pdf.
Btw, can you please be more specific?
I dislike guessing what someone means.
I like Serena said:
What is MIT?
\begin{aligned}
\end{aligned}
\begin{align}
&= -\rho\frac{d^2\mathbf{r}}{ds^2}\cdot \left(\hat{\mathbf{u}}\times
\hat{\mathbf{n}}\right)_t
\end{align}
Now let's write \(\frac{d^2\mathbf{r}} {ds^2}\) as
\begin{align}
\frac{d^2\mathbf{r}}{ds^2} &= \frac{d^2\mathbf{r}} {dt^2}
\left(\frac{dt} {ds}\right)^2\\
&= \frac{1} {v^2}\ddot{\mathbf{r}}
\end{align}
and substitute back into equation above.
\begin{align}
&= -\frac{\rho} {v^2}\ddot{\mathbf{r}} \cdot \frac{\rho} {v^3}\left(\dot{\mathbf{r}}\times
\ddot{\mathbf{r}}\right)_t\\
&= \frac{\lvert\dot{\mathbf{r}}\rvert} {\lvert\dot{\mathbf{r}}\times \ddot{\mathbf{r}}\rvert}\dddot{\mathbf{r}} \cdot \frac{1}{\lvert\dot{\mathbf{r}}\times \ddot{\mathbf{r}}\rvert} (\dot{\mathbf{r}}\times\ddot{\mathbf{r}})\\
&= \frac{(\dot{\mathbf{r}} \times\ddot{\mathbf{r}}) \cdot
\dddot{\mathbf{r}}}
{\lvert \dot{\mathbf{r}} \times\ddot{\mathbf{r}} \rvert^2}
\end{align}
So I still have a \(\lvert\dot{\mathbf{r}}\rvert\)
FAQ: How Do I Take the Dot Product of a Complex Expression with Itself?
What is the dot product?
The dot product, also known as the scalar product, is a mathematical operation that takes two vectors as input and returns a single scalar value. It is calculated by multiplying the corresponding components of the two vectors and then adding the products together.
How is the dot product calculated?
The dot product is calculated by multiplying the x-component of one vector by the x-component of the other vector, then multiplying the y-component of one vector by the y-component of the other vector, and finally adding these products together. This process is repeated for each component of the vectors. The resulting sum is the dot product.
What is the geometric interpretation of the dot product?
The dot product can be used to calculate the angle between two vectors. If the dot product is positive, the vectors are pointing in a similar direction and the angle between them is acute. If the dot product is negative, the vectors are pointing in opposite directions and the angle between them is obtuse. If the dot product is zero, the vectors are perpendicular to each other.
What are the applications of the dot product?
The dot product has many applications in mathematics, physics, engineering, and computer science. It is used to calculate work done by a force, to determine whether two vectors are orthogonal, to calculate projections, and to find the angle between two vectors. In computer graphics, the dot product is used to calculate lighting and shading in 3D environments.
Can the dot product be negative?
Yes, the dot product can be negative. As mentioned earlier, a negative dot product indicates that the two vectors are pointing in opposite directions and the angle between them is obtuse. This is because the dot product is calculated by multiplying the magnitudes of the vectors and the cosine of the angle between them. If the angle is obtuse, the cosine is negative, resulting in a negative dot product.
