How do I translate periodic motion to translational motion?
In summary, the engine emits a sound of frequency 750 Hz, which means it makes 2000 revolutions per kilometer. The book says that the car will travel 340 kilometers per hour as a result.
Eclair_de_XII
1,083
91
"Each piston of an engine makes a sharp sound every other revolution of the engine. (a) How fast is a race car going if its eight-cylinder engine emits a sound of frequency 750 Hz, given that the engine makes 2000 revolutions per kilometer? (b) At how many revolutions per minute is the engine rotating?"
##f=750s^{-1}=750Hz=\frac{375}{\pi}\frac{rev}{s}##
##r=\frac{2000rev}{1km}##
##v=\frac{f}{r}=\frac{1km}{2000rev}(\frac{375}{\pi}\frac{rev}{s})=\frac{3}{16\pi}\frac{km}{s}=\frac{675}{\pi}\frac{km}{hr}##
The book says that it's ##v=340\frac{km}{hr}##. I don't understand what I am doing wrong.
I'm not sure why you are using π. You just need to consider that one revolution of the engine results in the car moving a distance of 1/2000 km. And from the frequency of 750 Hz, you should be able to calculate how many revolutions the engine makes every second. From that you should be able to calculate the distance the car moves every second.
By the way, I did not get the same answer as the book, but I rushed my calculation.
So ##750 Hz## is 750 cycles per second, which is, I take it, to be 750 revolutions per second?
Eclair_de_XII said:
So 750Hz750Hz750 Hz is 750 cycles per second, which is, I take it, to be 750 revolutions per second?
I believe what they are implying is that it is a 4-stroke engine and that it makes a sharp sound when the spark plug fires causing combustion in a given cylinder. In other words, the combustion (and sharp sound) does not occur every revolution for each piston; it occurs every other revolution for each piston. But you have to remember that there are 8 pistons and that each piston is making a sharp sound every other revolution. And they are basically telling you that there are 750 sharp sounds every second. So based on that you can calculate the number of rotations (Edit: revolutions) the engine makes every second.
Edit 2: I think it would simplify it if you work in meters and seconds and then convert to km/hr at the end. That's just my personal preference though.
Okay, so there is one sharp sound every two revolutions, then. There are eight revolutions, so four sharp sounds... I'm guessing: ##v=\frac{750rev}{4s}(\frac{1km}{2000rev})(\frac{3600s}{1hr})=337.5\frac{km}{hr}##.
That looks right to me. After looking at your result, I realize that my answer was wrong because in my mind I calculated 750/4 = 175. It should have been 187.5. Thus my error.
Good job!
Thanks. It's the first time I'm doing a frequency problem, and you've been a great help.
Likes TomHart
FAQ: How do I translate periodic motion to translational motion?
1. How do I calculate the velocity of an object undergoing periodic motion?
To calculate the velocity of an object undergoing periodic motion, you can use the formula v = 2πfA, where v is the velocity, f is the frequency, and A is the amplitude.
2. What is the difference between periodic motion and translational motion?
Periodic motion refers to the repetitive movement of an object around a fixed point, while translational motion refers to the movement of an object from one location to another without any rotation or change in orientation.
3. How can I convert a periodic motion function to a translational motion equation?
To convert a periodic motion function to a translational motion equation, you can use the formula x(t) = A cos(2πft), where x is the position, A is the amplitude, f is the frequency, and t is time.
4. What factors affect the conversion of periodic motion to translational motion?
The factors that affect the conversion of periodic motion to translational motion include the amplitude, frequency, and mass of the object, as well as any external forces acting on the object.
5. Can translational motion be represented by a sinusoidal function?
Yes, translational motion can be represented by a sinusoidal function, as shown by the equation x(t) = A cos(ωt + φ), where A is the amplitude, ω is the angular frequency, and φ is the phase angle.
