Ilikebugs
- 94
View attachment 6582 I know that d is 5, but I don't know how to use the inequalities to find f(3)
Ilikebugs said:I know that d is 5, but I don't know how to use the inequalities to find f(3)
Ilikebugs said:I don't know how to solve that
You should do it on paper instead. (Smile)Ilikebugs said:this is hard to do in my head.
How did you get $a^3$ if in the original formula for $f$ the coefficient $a$ is never raised to any power, only $x$ is.Ilikebugs said:I got 8a^3+4b^2+2c+5=-3, 64a^3+16b^2+4c+5=45, and 216a^3+36b^2+6c+5=245
HallsofIvy said:What inequalities do you have for f(4)? Same for f(6).
Is there a reason you don't want to do this?Evgeny.Makarov said:Follow HallsofIvy's advice.
In general, if you had four equations $f(x_i)=y_i$, $i=1,\dots,4$ with known $x_i$ and $y_i$, you could write four linear equations in this way and thus find the coefficients $a,\dots,d$. Here, however, you have one equation, four inequalities and the stipulation that the coefficients are integer. This makes it a little trickier. But I still would first write the four inequalities on $a$ and $b$.Ilikebugs said:8a+4b+2c+5=-3
64a+16b+4c+5=45
216a+36b+6c+5=245
Yes.Ilikebugs said:Is a=2 and b=-5 correct?
Try to compare, or match,Ilikebugs said:How do I do that?
A function in science is a relationship between two or more variables that describes how one variable changes in response to changes in the other variable(s). It is often represented in the form of an equation or graph.
Scientists use functions to understand and describe natural phenomena, make predictions, and test hypotheses. Functions are also used to model and simulate complex systems, such as weather patterns or population growth.
A function has three main components: the input variable(s), the output variable, and the relationship between them. The input variable(s) are the independent variable(s) that can be changed, while the output variable is the dependent variable that is affected by the changes in the input(s).
Yes, functions are commonly used to solve real-world problems in various fields of science, such as physics, biology, and economics. For example, a function can be used to calculate the trajectory of a projectile, model the growth of a bacterial population, or predict the stock market trends.
The type of function is determined by the relationship between the input and output variables. Some common types of functions include linear, quadratic, exponential, and logarithmic functions. The type of function can be identified by analyzing the pattern or shape of the graph or by looking at the equation that describes the relationship between the variables.
