MHB How do I use the midpoint formula to find the coordinates of point C?
  • Thread starter Thread starter mathdad
    Coordinates Point
To find the coordinates of point C given that B(5, -3) is the midpoint of segment AC, use the midpoint formula. The formula results in two equations: (x - 1)/2 = 5 and (y + 2)/2 = -3. Solving these equations yields the values for x and y. The process confirms that the midpoint formula effectively determines the coordinates of point C. This method is essential for solving similar midpoint problems in geometry.
mathdad
The coordinates of A and B are A(-1, 2) and B(5, -3). If B is the midpoint of line segment AC, what are the coordinates of C?
I know this question is connected to the midpoint formula. If so, how do I use the formula to find the x and y coordinates of C?
Mathematics news on Phys.org
Let's label the coordinates of point $C$ as $(x,y)$...then (as you correctly surmised), the mid-point formula gives us (since $B$ is said to be the mid-point of $\overline{AC}$):
$$\left(\frac{-1+x}{2},\frac{2+y}{2}\right)=(5,-3)$$
This gives us 2 equations:
$$\frac{-1+x}{2}=5$$
$$\frac{2+y}{2}=-3$$
Solving each will give you the values of $x$ and $y$. :D
I knew this would lead to two equations. Thank you for your help.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
